'90 YX600 Radian parts needed
Discussion in 'Other Motorcycles' started by Micrometer, Jan 13, 2015.
  1. Micrometer
    Micrometer New Member
    florida
    After some carb cleaning and brake work the Radian 600 was put back on the road last year. It ran well until it was warmed up. The idle kept increasing and couldn't be adjusted. The carbs were removed and the throttle shaft seals were found to be hard, brittle and leaking. I'm looking for the parts to replace them. These are the Mikuni BS30 - IUJ00 series. I've messaged Chacal and am hoping he can match these seals up with parts from the other models in which he specializes.
    Does anyone else have any experience, suggestions or ideas to help get the Radian back on the road?
    Thanks,
    Micrometer
  2. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    86 thru 90 Radians are all the same. They use the same carbs as an XJ550. I got throttle shaft seals from Chacal for my son's Radian.
