Wiring diagram
Discussion in 'XJ Modifications' started by Stoopkid22, Jan 27, 2015.
  1. Stoopkid22
    Stoopkid22 Member
    Virginia
    will this diagram work on the xj? If not, why? Is there anyway I could make it work?
  2. Urra
    Urra Member
    Miami, FL
    I was wondering the same. bump
  3. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    I was told by a fellow builder that this will work just fine. But I can't put my own experience behind it yet
  4. Urra
    Urra Member
    Miami, FL
    I feel you on that. I'm a newbie and really want to make my own simplified harness because I like things to be straight to the point
  5. Stoopkid22
    Stoopkid22 Member
    Virginia
    I really hope it works. I'm gonna try it. It's my first build and I HATE wiring
    Urra likes this.
  6. Urra
    Urra Member
    Miami, FL
    Goodluck mate! keep it updated!
  7. Shaynus
    Shaynus Member
    Mandurah, Western Austalia
    I'm certainly no expert but I would be using relays in the headlight circuit.
    (And possibly the starter solenoid circuit too, depending on current draw?)
  8. MiCarl
    That schematic is virtually useless. You have a different type of ignition and a different type of alternator than pictured. Half of the wiring you need is not shown.
    Also, I consider it poor for what it is. At a glance I see that the brake light won't work if the headlight isn't on. The fuse on the lighting system should be up stream of the switch, not downstream as designed.
  9. Stoopkid22
    Stoopkid22 Member
    Virginia
    Do you have one I could use? What wiring isn't shown?
  10. MiCarl
    No I don't. There really isn't anything extra in the stock wiring. If you've got a problem with the harness it's probably best to just repair it.
  11. FtUp
    FtUp Well-Known Member
    pacific northwest
