stuck cylinder head question
Discussion in 'XJ Technical Chat' started by dizzycow, Feb 12, 2015.
  1. dizzycow
    dizzycow Member
    Huntsville, AL
    I have removed all bolts required to remove the cylinder head but i just can't get it free. i've hit it with a rubber mallet all over the corners and front and back and side. even used a tire iron to pry a little and managed to get left half to lift up maybe an eighth of an inch but i just can't get it off. Do you need to remove the automatic cam chain tensioner to remove the cylinder head? bike is an 82 xj650 maxim.
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    Did you pull the camshafts already?
    By the book you remove the tensioner, rotate the crank counterclockwise to TDC, then unbolt the cam sprockets. Slip the sprocket off the cam, remove the chain (slide off sprocket, don't actually break the chain), then remove the camshafts. 12 bolts on top and 2 between the cylinders and head.
  3. hogfiddles
    Did you remove the bolt that is HIDDEN inside the oil filter cavity ?!?!? If not, you'll pound hard enough to break something you really don't want to break
    DAVE
  4. hogfiddles
    Oh wait.... Just noticed you said head not jug, my bad. Make sure you got the two bolt that are centered at the front and at the rear of the head.
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    You had me worried Dave! I went out to look at the manual again, I didn't recall any such bolt for the head on mine ;)
  6. Polock
    home depot or such has plastic shims for doors and windows, tap 3 or 4 of those in until you get 2 to the middle of the head the then take the shims out of the side that's up and tap it down. the head should rock on the middle shims and pop up on the tight end
    jmilliken and dizzycow like this.
  7. dizzycow
    dizzycow Member
    Huntsville, AL
    oh okay, thank god i was like man all that time tryna wiggle this bitch off and i forgot to unscrew something.but I don't need to take out the actual cam chain tensioner mechanism? (y shaped object)? and Polock that's actually really smart, i'll give it a try this weekend.
    Thanks for the replys ya'll!
  8. Polock
    there's some dowel pins in there that can rust and get stuck pretty tight. it might help if you squirt some penetrating oil in the gap, maybe it'll help
  9. dizzycow
    dizzycow Member
    Huntsville, AL
    Yeah i'll try that. Pb blaster? Or would wd40 suffice
  10. hogfiddles
    Kroil, or PB blaster
    dizzycow likes this.
  11. KDub
    KDub Member
    Burnley, NW UK
    They can be a swine. Keep trying, Polock's advice sounds good, ten times better than what I ended up doing to get mine off.
  12. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Just go gently!!!! Be careful, take your time.
    ThatS my 2 cents to add to what these 2 fine gentlemen said..,,
