Rear Shock disassembly question
Discussion in 'XJ Technical Chat' started by dmschuler, Apr 22, 2009.
  1. dmschuler
    dmschuler Member
    Tonawanda, NY
    Good morning!
    I'd like to paint the rear spings, but want to remove them from the shocks first. Is it as easy as compressing the springs then removing the plate at the top? or is there more to it than that....
  2. truckerbikes
    truckerbikes Member
    queensland australia
    a couple of things you will need. a sturdy work bench and a good vice. to control the shocks and an extra set of hands.
    set your shock in the vice by gripping the lower mount by the outer ring,( a pair of alloy angles in the jaws is recommened). next set the spring pretensioners to their lowest setting.
    grip the spring around the top and pull down whilst you friend keeps the top of the shock at full extension he/she should be able tp pry/lift the upper retaining ring out of its seat and of the shock. release the pressure slowly or you will find the spring will try and launch itself into the ceiling. reverse the above to reinstall. good luck
  3. dmschuler
    dmschuler Member
    Tonawanda, NY
    sounds very similar to removing a coil spring from a strut. Do I need to turn the retaining ring - is it keyed?
  4. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    I have that same question - is the retaining ring keyed, and is it simply a matter of turning it to remove ti once the spring is compressed below it by some means?
  5. Altus
    Altus Active Member
    London, Ontario
  6. 4nik8r
    Ottawa, ON, Canada
    Well....I actually managed to find a way to do it all by myself with just a vice and a lever through the upper bolt hole. A "helper" to remove the cap would have made it easier so I would have more than one hand for both the shock and lever.
    Now for reassembly this weekend....
