1985 XJ700N Piston Rings
Discussion in 'XJ Technical Chat' started by Henry151, Feb 24, 2015.
  1. Henry151
    Henry151 New Member
    Weehawken NJ
    Hello there folks,
    In the shop I manage there is a 1985 Maxim XJ700N completely torn apart for a customer, and to put it back together we need piston rings. Part number is 1FG-11610-00-00. I have searched to my wits end to no avail. I'm asking for any assistance you might be able to provide. Thanks!
  2. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Send a message to the member Chacal and he will get you all setup. He has the best prices and best customer service and quick responses
  3. DaveStokes
    DaveStokes Member
    Valdosta, GA
    from what I understand, the rings are no longer available for the 85 xj700. seems I read that somewhere on here and it stuck since i have that bike as well.
  4. DaveStokes
    DaveStokes Member
    Valdosta, GA
  5. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Good luck dude. I had to pull rings off my parts motor. I have 6 remaining + 2 slightly bent. You could probably talk me in to parting with them...
  6. Rod1
    Rod1 Member
    San Luis, Argentina
    so what rings can fit on then??
  7. jmilliken
    Dillsburg, PA
    I dont know. I used good used rings. finding a compatible ring from anything would be a lifesaver.... But i have not heard of one yet..,
  8. Kickaha
    New Zealand
    Over here I can walk into a local engine reconditioner and they can either make me rings or find something similar that will fit
    There must be other bikes which share the same size bore which will have rings that can be used
  9. jmilliken
    Dillsburg, PA
    I might have to check that out
  10. Rod1
    Rod1 Member
    San Luis, Argentina
    A machine shop can easily do them, but if someone can post the measure of those I could make me a set just in case...
  11. Ivo Petric
    Ivo Petric New Member
    Zadar/Croatia
    Hi I heave a problem with rings.I ordered from ebay set for my xj700n,they sent me 68 mm rings (piston is 65) what shall I do.
    On box is written
    1AA-11610-00 in catalog is written that it is for xj 700
  12. a100man
    a100man Well-Known Member
    Bedford, UK
    Send them back and try something else. There must be a more common 8-valve bike that uses 65 (or 66)mm bores that will fit. Quick google shows CB750 'big bore kits' are 65mm - worth buying a scrap CB750 piston (or ask on a forum) for pin to crown dimension. Where there's a will..
    DrewUth likes this.
  13. Toomanybikes
    Tsawwassen bc
    Might be easier to find a spare engine or look north of the border for a 750 engine
    The 1AA part number is for the X model water cooler engine
    So you have the air cooled 700 yes?
  14. k-moe
    An XJ700 is a destroked XJ750. I am not positive that the 750 piston rings will work on the 700 pistons, but I'm sure someone will come along (now that I've posted) and tell us.
  15. Radosław
    Radosław New Member
    Poland
    I also searched this information. I've compare pistons and rings of xj700 and xj750. Two upper rings in xj750 are 0,2mm thicker than xj700 (1,2mm / 1mm). Piston of xj700 is more convex (higher compression ratio).
