Xj550 seca float height?
Discussion in 'XJ Technical Chat' started by ecologito, Feb 25, 2015.
  1. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Hi,
    I am gonna set the float level on the 550 seca and I am curious if somebody knows how to measure the floats and what height before closing and trying the first wet set.
    I have two floats at one height and noticed two at different heights. I am just curious about the starting point before the wet set
  2. BleedingOxide
    BleedingOxide Member
    Brighton UK
    My floats sit 19.8mm above gasket height at their highest point, so mebbe start there.
    Wet set 2mm below the lip (+/-1mm)
    I found that a 6mm clear plastic tube has a 2mm Meniscus. very convenient.
    ecologito likes this.
  3. hogfiddles
    Yamaha used to post that the 550 carbs were to be initally set at 21.5mm. Now they don't post a number, just say to set fuel height.
    Mikuni BS28 (All 550 except 550L)
    2mm +/- 1mm (.08" +/- .039")
    Mikuni BS32 (all 550L)
    3mm +/- 1mm (.12" +/- .04")
    I still set the 550 carbs at 21.5mm for initial setting.
    Dave Fox
  4. ecologito
    NASCAR Country, NC
    Thank you for the info,
    I have been able to easily find info on the wet set height but I guess the dry set (starting point) is becoming more of a guesstimate since you have to wet set anyways.
  5. ecologito
    NASCAR Country, NC
    I just set them at 21.5 mm and they all were really low (about 4 mm below that mark). Now it will be a matter of looking at the wet set and see what they do.
  6. hogfiddles
    Do you mean they were low before you set them to 21.5mm, or "after you set them at 21.5mm, and then did a wet check, they fuel level was too low"?
    I read that first, and made a few comments to others, then just re-read it and now translated it differently. So, I'm checking with you.
    Now, I'm assuming you mean that "while the bowls were still open and upside down, the floats were too low and were not reaching the 21.5mm mark yet" (cuz you know, if the floats are to low if the carbs are upside down, then theyre really too HIGH, and if they are too high when the carbs are upside down, then they are really too LOW.
    Just checking specifically what you mean.......LOL
    Dave F
    XJ550H likes this.
  7. ecologito
    NASCAR Country, NC
    When I checked the floats as they came out of the bike they were below 21.5 mm my guess between 17 and 18 mm. I have set them all to 21.5mm so far. I have not done a wet set yet as squirrels chewed through my gas bottle when it sat out on the driveway.
    Not sure why a squirrel would want to chew on a red plastic container that smells like gas... little jerks!
  8. hogfiddles
    Ok..... that's just what I was wondering!! I read the post the other day, and understood it totally differently. THEN......last night re-read it and had a different take on it, that's why I thought I'd better ask. That makes me feel better.
    Thanks, Eco.
  9. Toomanybikes
    Tsawwassen bc
    Ok Dave
    To what point do you measure to
    A -metal tang
    B -plastic body
  10. hogfiddles
    I measure those at point B
    Toomanybikes likes this.
  11. XJ550H
    if you do wet set on one carb before reassembling the rack you can get a setting with out all that gas in the other carbs
    then set the floats on the other carbs to that setting as a starting height. eliminates a step.
    kosel and Toomanybikes like this.
  12. 1jeffs
    1jeffs New Member
    Upstate NY
    Hi Dave, how do I know if I have the 28 or the 32. It’s an 82 maxim 550. Thanks
  13. hogfiddles
    The 550L was 1984. Yours is 1982, so it’s not a L.
    also, as I understand it to be, and find it to be true..... the 550 racks are pretty finicky. The fade setting of 21.5 seems to be to just get you in the neighborhood of where the wet set will be, unlike the 650/750 which is usually pretty darn close. The mixture screws also tend to have to be adjusted farther either way on the 550.
    ALSO, most of the time it’s not worth the hassle of re-installing the heat shield either, cuz You gotta take it back off to remove a bowl. If you take that off, now you’ve just disrupted your sync, cuz the shield is held on by the same bolts that hold the lower rail in place.
    dfox
  14. 1jeffs
    1jeffs New Member
    Upstate NY
    Thanks for the info. So looks like I will be using the 2mm +\- spec. And I have a top bracket on my carbs so I was able to remove the heat shield and reinstall the lower bracket without moving the carbs at all. ( I hope).
  15. hogfiddles
    that’s right.... you hope—-
  16. 1jeffs
    1jeffs New Member
    Upstate NY
    Will any size tubing work? I read 6mm ID someplace but that won’t fit in the holes. I have some that fits great in the holes but it’s small ID. With the hose I have I am level with top edge of bowl on all 4 carbs with the carb top covers level. What are your thoughts other than the fact fuel is too high? Thank you
  17. XJ550H
    you have to buy a nipple from xj4ever to fit into the hole. or get a vacuum fitting from autoparts store and taper it to fit.
    hose does not go inside hole
  18. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    This is what I use on the Hitachi carbs, may be different sizing for you. Clamp the larger section to the bowl drain hole, flex the smaller hose easily to any shape to get a good reading. I was tired of fighting with the large diameter tubing.
  19. XJ550H
    he has no nipples
    we use this handy contraption – since the Mikunis have Innies instead of Outies (like the Hitachis), we can’t just plug in a hose. www.maxim-x.com shows how it’s made.
    http://www.maxim-x.com/fuel_level_gauge.html
    Mikuni BS28 (all XJ550 except 1984 XJ550L): -Fuel level measured via the clear-tube gauge: 2mm +/- 1mm (.08 +/- .039 inches) -Float height: 21.5 +/- 1.0mm
  20. hogfiddles
    Oh man, for a second there I was thinking MattiThundrr was back
    jayrodoh likes this.
  21. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    This is what I came up with.
    If you've ever bought a replacement battery chances are they supplied you with the correct size drain tube.
    Use the insulators from these commonly available terminal ends and it provides enough stiffness to the tubing.
    hogfiddles likes this.
  22. hogfiddles
    I always save those tubes too.,..ya never know when you you’ll need them. Well.....NOW we know! Lol
  23. 1jeffs
    1jeffs New Member
    Upstate NY
    Thank you everyone for your input. I was able to sand down a vacuum Tee to fit. The larger hose worked fine and luckily all my carbs were in spec. Although after I put the new bowl gaskets on and the rest of the screws and heat Shield. Checked the butterfly gaps and installed on the bike. Got her running for the first time since probably 2001. Unfortunately the left carb was leaking into the air box, however a slight tap on the bowl fixed that for me. Hopefully it was just a fluke. Now to figure out how to contact the XJ forever parts people to order PETCOCK parts.
  24. hogfiddles
