Front brake pad
Discussion in 'XJ Technical Chat' started by andrew15, Mar 5, 2015.
  1. andrew15
    andrew15 Member
    Montreal, Canada
    On one of my front brake pad i'm missing that thing piece of metal, believe its referred to
    as a the shim?
    How important is it?
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    The piece of metal that goes behind the pads? It helps hold the pads in place.
  3. Wirehairs
    Wirehairs Member
    St. Paul, MN
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    you can manage without it if you wish, it stops the pads from rattling, whilst you're on the move, may also help to reduce squeal whilst braking.
    stu
  5. andrew15
    andrew15 Member
    Montreal, Canada
    Yeah i heard of it as an anti squeal shim I think... if you guys lost one would you replace it?
  6. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    I had that pad missing on my 550 seca and ended up fabricating one out of a sheet of stainless steel, because without it the pad was loose enough that it would jam when trying to back the bike up with the wheel turned, making reversing the bike a real PITA.
  7. andrew15
    andrew15 Member
    Montreal, Canada
    That's actually what I just said to myself haha i'll probably be doing that
  8. k-moe
    You can get by for a while if you use high-temp silicone to "glue" the pads against the caliper and the piston. Just use a little.
