What else should I consider?
Discussion in 'XJ Technical Chat' started by ronha13, Mar 14, 2015.
  1. ronha13
    ronha13 Member
    Curtiss Wisconsin
    I will be replacing my clutch in a couple weeks... friction plates, springs, gaskets...ect.
    Should I replace the main plates as well, or just inspect them when I take it apart?
    I will also replace my valve cover gasket as it has been seeping since I did the valve job on it.
    Is there anything else I should replace while I doing the clutch?
    Thanks.
    Ron.
  2. hogfiddles
    Valve shim clearance check
    Brake check
    Tire check
    Colortune check
    Sync check
    Etc....
  3. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Check everything. It doesn't take that long. Have you read Fitz's clutch replacement thread? That spells it out pretty well. The plain plates SHOULD be fine, but you still wanna clean them up with scotchbrite or something similar.
  4. ronha13
    ronha13 Member
    Curtiss Wisconsin
    I decided to replace the main plates as well since I will already have everything apart.
    Thanks for all the help :p
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Throw out rod (through the cover) seal and the oil filler cap o-ring.
    Gary H.
  6. ronha13
    ronha13 Member
    Curtiss Wisconsin
    I placed my order today but I probably should have waited.
    I had inguinal hernia surgery yesterday (Fri) and am on some pretty good meds! lol
    I might have ordered a wrong part :(
    But I'm pretty sure Chacal will straighten it out for me. ;)
  7. ronha13
    ronha13 Member
    Curtiss Wisconsin
  8. rocs82650
    Middle Tennessee
    Wait until the meds wear off so you don't brake the colortune and synch the rear tire.
    Gary H.
    jmilliken likes this.
  9. ronha13
    ronha13 Member
    Curtiss Wisconsin
    lol
