connection behind clutch broken
Discussion in 'XJ Technical Chat' started by hamz777, Mar 18, 2015.
  1. hamz777
    hamz777 New Member
    Michigan
    It broke while switching bars. Xj650. What does it do?
  2. Lokitruck
    Lokitruck Member
    Bealeton,va
    I'm curious about this to as mine is broken there too
  3. JaiFer
    JaiFer Member
    Northern Ontario
    I believe that's your clutch safety switch, so you don';t start in gear. Should go into your headlamp bucket.
  4. k-moe
    ^That^ is exactly correct. They are still available new from Yamaha. Chacal carries them.
  5. Lokitruck
    Lokitruck Member
    Bealeton,va
    Do i have to have it? Im going to try and do a minimum wiring diagram so i was just wondering if i needed it
  6. JaiFer
    JaiFer Member
    Northern Ontario
    I wouldn't recommend disabling it, as the bike will start in gear. Much simpler to replace it. There should be 2 wires going to the headlamp bucket and theres a very small hole where the wires go to the clutch lever and just insert a small awl into the hole, there a small snap in there, once it release you can pull the lead off it and reverse the procedure to put it on.
  7. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Take it from someone who used to have a Sportster with a key-turn type starter, you will only try and start the bike in gear ONE time, after that you will rock the bike in neutral every time before attempting to start it.
  8. CapnRedbeard
    CapnRedbeard Member
    London England
    I agree with BSHank In addition to the clutch switch however you have a side stand switch and a neutral light.
  9. Polock
    after you get rid of all that safety stuff and tune it up, try this.
    in gear, clutch out, stand down, standing on the left side with your right foot on the peg. Now hit the starter, sit on it and put the stand up all in one motion while you drive away.
    only do this around people who already know your a goof ball :)
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Smooooooooooooth!
  11. Bigshankhank
    Bastrop, TX
    I actually watched a young lady do this on a KTM super moto up in Tennessee, I wondered how the hell she was going to get up on that bike. Next thing I knew, with the bike on the stand the whole time, she stood on the left peg, threw her leg over the saddle, and in one motion stomped down on the kicker and used the momentum to heave the bike off the stand and swept it up then rode off.
  12. MattiThundrrr
    Is it weird that I find that kinda hot? I don't mean just you, Polock! Young, competent lady on a big fast bike? Too cool! And she's into reckless action? My kinda girl!
