The Wheels on the Bus... er... Bike go 'Round and 'Round
Discussion in 'XJ Technical Chat' started by Old_Ironsights, Apr 3, 2015.
  1. Old_Ironsights
    Old_Ironsights Member
    Riverton WY
    I may be all wet, but I think my clutch is dragging...
    Because my rear wheel rotates ever so slightly when in Neutral and a bit more when in gear but clutched.
    You can feel the pull if you stop the rotation with a finger.
    I'm guessing this is NOT normal and my clutch needs to be looked at?
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    To me that is normal. As long as it is disengaging enough to select a gear at a stoplight.
  3. FtUp
    FtUp Well-Known Member
    pacific northwest
    it's a wet clutch, there is gonna be fluid connection even when the trans is in neutral, so you will get some drag.
    FU
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If you can stop it easily with a finger than that's normal, at least it is for all of my 5 bikes.
  5. Old_Ironsights
    Riverton WY
    OK, thanks. Like I said, when it comes to Gears, even the US Army told me "find something else to do"... so I learned how to kill Cities rather than fix Trucks...
