side covers options xj550h
Discussion in 'XJ Modifications' started by saftie, Apr 2, 2015.
  1. saftie
    New York, NY
    What side covers will fit a 81 xj550 maxim that cover most of the triangle?
    I tried the xj650 ones, but if i remember correctly, one side stuck out too much.
    Want to look for existing options first before building my own. Or if you fabricated your own, do you have pics?
    Thanks,
    Gabor
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
  3. saftie
    New York, NY
    Thanks, but not looking to buy an original xj550 piece. Looking for something that is bigger and covers more of the battery/airfilter side
    Know what I mean?
  4. saftie
    New York, NY
    Hi FU,
    Here a pic of 650 covers. Still too much space top and bottom. Any other alternatives?
  5. saftie
    New York, NY
    Unless I fiber glass the top. Bottom is ok, actually
  6. JustinOther1
    JustinOther1 Member
    Indiana
    I was gonna say, you might have to custom fabricate something, and that 650 panel looks like a great starting point if you're up for it. Will the seat fill in any of that gap?
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    What's your plan for cup holders? Don't think diamond plate is gonna hold it!
  8. saftie
    New York, NY
    Lol.
    Only used the diamond plate as template to get the shape for the seat pan. It is now fiber glass. Have another thread running on here that shows it.
    unfortunately, the seat is not going to fill in any of the gaps, not going back to stock. Still undecided whether to do fiber glass add on or completely from scratch. Was hoping there was a Plug and play solution, hence my thread :)
  9. hogfiddles
    No, there's not any direct swap.
  10. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    Open frame :):) Since that's not what you actually asked, I don't see why you couldn't fiberglass your own if you don't have a good solution.
    Is that a CB750 tank?
  11. saftie
    New York, NY
    yeah, will go down that route and fiber glass something.
    tank is off a suzuki.
  12. JustinOther1
    JustinOther1 Member
    Indiana
    It may sound stupid, but I would mock something up in card stock or with cardboard. Just break out the Elmers and start cutting and pasting until you get something halfway pretty. That way you'll know roughly what it will look like and have a mock up of it to lay your fiberglass/bondo on when you start actually making a piece if you're not going to modify the 650 panel. I know how much of an ordeal fiberglass can be, and it'd suck to get something together only to decide it doesn't look right.
  13. saftie
    New York, NY
    yes sir. that is what i am going to do :)
    i will most likely get a thin aluminum sheet that i can bend into place and put fiber glass on top. once dried, i can easily take it off. this would also give me a smooth surface and i have less sanding afterwards.
