Morgan Carbtune vs Motion Pro Carbtuner
Discussion in 'XJ Technical Chat' started by kwes, Apr 14, 2015.
  1. kwes
    kwes Member
    tampa
    Clueless as to which is better and why.. but i know this forum is home to some of the most knoweldgeable folks.. so what say you guys?
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    well I have no experience with either, but I have plenty experience with multiple carb setups and balancing them, and I can say that there are many viable ways to tune your carbs.
    FU
  3. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I have the morgan carbtune
    it uses steel rods instead of fluid
    both will do the job
    but I really like the Morgan, very simple to use
  4. hogfiddles
    I love my Morgan carbtune pro
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I love my Morgan!
  6. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Love the Morgan! No calibration no fluid to deal with.
  7. kwes
    kwes Member
    tampa
    sounds like Morgan is the way to go! i was sold at "no calibration"
  8. hogfiddles
    exactamundo
  9. FtUp
    pacific northwest
    I have this, and couldn't be happier. both my bikes run like a top, and I used this to sync the carbs...
    http://www.ebay.com/itm/UNIVERSAL-M...399?pt=LH_DefaultDomain_3&hash=item35e855a437
    at a fraction of the cost of a morgan carbtune, how can you go wrong? I can sync a set of carbs in less than 5 minutes with this setup.
    FU
    JaiFer likes this.
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    I've used gauges, homemade boards/manometers, and recently purchased a carbtune. I'm sold on the carbtune and wish I would've got one sooner. No calibration, no dampers to adjust, easy to hang on the bars and responds to the changes very quickly.
    I'm not familiar with this one, but the "base carb instructions" in the description don't seem like they would work on these bikes since there is not 1 carb that is not adjustable and would be a good reference. Would you sync 1&2, then 3&4, then 2&3 for the pairs? I also like being able to see all 4 at the same time to ensure it's good.
  11. FtUp
    pacific northwest
    one tube has a reference ball, the other tube connects between 2 carbs. you adjust the carbs till the reference ball matches with the other one. yes 1&2 then 3&4 then 1/2&3/4. takes me all of about 5 minutes and works perfectly. it also stores easily in a sandwich sized Ziploc bag.
    FU
  12. JaiFer
    JaiFer Member
    Northern Ontario
    I just got mine last week. Took less than 5 mins., considering it's the first time I've done a running sync. Cheap but had to wait 3 1/2 weeks from GB to Canada
    FtUp likes this.
  13. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I've got the Morgan also. Works great.
  14. FtUp
    pacific northwest
    I'm sure the morgan carb tune works great, but for the price, you can't beat the setup I am using.
    FU
  15. waldreps
    waldreps Active Member
    Henning, MN
    Has anybody used the Harmonizer? It's an electronic device made by a member of another bike forum. He's been selling hundreds and hundreds of them. They're in the price range of a Carbtune (maybe a little more depending on where you buy the Carbtune) but are supposed to offer super accuracy and ease of use. It's a two-port synchronizer that also has a gauge and tach. Here's the link to where the guys sells them:
    http://www.advrider.com/forums/showthread.php?t=701625&highlight="inmate+discount"
    As soon as he has some more available, I'm going to order one. I'll post back to let everyone know how it works.
  16. k-moe
    Unless something changed recently he hasn't been making any for almost a year now. I like the idea, and think it works fine, but the fewer batteries I have to buy the better.
  17. waldreps
    Henning, MN
    He's making them again k-moe. I placed my order the other day. He sells out as quick as he has stock back in.
  18. k-moe
  19. waldreps
    Henning, MN
    I got my Harmonizer yesterday and used it tonight to do a carb sync. It worked great and helped make the engine sound much smoother. The Harmonizer has a balancer to do the sync with and shows you a graphical scale left to right between the two carbs with the middle being exactly balanced. It also has a gauge function where you can hook up one carb at a time and get a vacuum reading. It is backlit with a sensor that turns off the backlight when not needed to save the battery. It has an auto-off function in case you forget to turn it off. It also has an LED that can be used in case you need a light. This display also shows the rpms which is really helpful. I'm impressed with it and think it's a great little tool.
    kwes likes this.
