why is it.....
Discussion in 'Hangout Lounge' started by Polock, Apr 18, 2015.
  1. Polock
    when i answer a post, that post is gone off of "new posts" the only way to see it again or to make another comment is to log off and back on.
    am i missing something?
  2. k-moe
    I haven't had that problem. Are you set to stay logged in?
  3. Polock
    stay logged in? no, but i can't see what that will do. after i click "post reply" i'am still logged in but this thread will be gone from my "new posts" tab until i log out. i'll try it but it almost seems like somethings wrong with my refresh
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Once you've viewed it, it is no longer a "new post". The new ones have a little blue indicator in the right hand margin that leaves once you've viewed them. Do you leave the thread when you hit "Post Reply"? Just tested it, and when I do, I'm still here.
  5. k-moe
    I thouht on this for a bit. I always open posts in a new window, which is probably why I haven't had that problem.
  6. MiCarl
    "New Posts" doesn't refer to their age. It means ones you haven't read yet. When you post something it is considered read by you.
  7. hogfiddles
    Everything's new only once. You might want to go into your personal settings and see if you need to change anything there, too......
  8. MattiThundrrr
    This is a decent philosophy for XJs too!
  9. FtUp
    FtUp Well-Known Member
    pacific northwest
    if you hover your cursor over your forum name in the top right, you will get a pop down list. in that list on the right, about half way down is "your content", click on that and you will find your last post at the top of the list.
    FU
  10. MattiThundrrr
    Clever, FU! I will be using that going forward. I know that once you visit all the new posts, there is a link to "recent posts", which shows what everyone has posted in reverse chronological order, but I can't find it when I haven't visited them all.
