Another "You'll Love this one" Making Idle Adjusting Easier
Discussion in 'XJ Technical Chat' started by RickCoMatic, Jul 13, 2007.
  1. RickCoMatic
    From the "Make it Easier" Department
    Very, very simple Mod's Division
    XJ-Bikes.com
    What a Pain in the ass it is to need ViceGrip Finger's and the strength of The Incredible Hulk to give the Idle Adjustment Rod an Accurate little tweak, when necessary.
    No more.
    Rejoice.
    Now you can adjust the Idle Rod without too much trouble any more.
    This is so simple ... a Caveman COULD do it.
    Just add a little washer between the Spring and the Rod at the end of the Spring on the KNOB Side.
    I used a Nylon washer. It give that Rod a real "Precision Instrument" feel and your hand spends less time making the tweak.
    Now your hand and wrist are just "Lightly-toasted" ... instead of "Medium-rare" or "Well-done!"
  2. gitarzan
    gitarzan Member
    Columbus Ohio
    I've a 550. I don't think my hands would fit in there when I was in the 5th grade let alone today. I have to nudge the notches wiith a long twig.
    And I resent that "caveman" remark. :wink:
  3. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Mine usually is loose enough and I use my fingers and just push on the appropriate side to adjust.
    Guess I was just lucky that mine was not so tight!?
