Not so fun on a 650 Maxim is...
Discussion in 'Hangout Lounge' started by Old_Ironsights, May 1, 2015.
  1. Old_Ironsights
    Old_Ironsights Member
    Riverton WY
    Wanting to ride to the next town of any real size... and realizing that to be safe you have to take a Jerry Can because it's over 100 mi away... with only one iffy petrol pump in between.
  2. k-moe
    Swap a 750 Max tank onto your wee beasty. It's about a gallon larger.
  3. Old_Ironsights
    Riverton WY
    That would be great. I didn't know if there was a bigger tank that would fit or not. Time to start looking for one.
  4. Old_Ironsights
    Riverton WY
    OK... Found one. Gonna need some cleaning up & new paint, cap, petcock, etc., but what can you expect for $60?
    [​IMG] [​IMG] [​IMG] [​IMG]
    Learning curves... :confused:
  5. k-moe
    Another upside is that the 750 tank has a fuel sending unit. You can either blank it off, or add a fuel gauge to your machine. There are a few threads about adapting, and making a fuel gauge for just that purpose.
  6. Old_Ironsights
    Riverton WY
  7. Polock
    Better not race that Kawasaki to the next town
  8. hogfiddles
    Looks like you have your work cut out for you with that tank.
    Not all 750 maxims came with a fuel sender
  9. Old_Ironsights
    Riverton WY
    Yeah. But It was a good enough deal that I figured "why not?". As long as there are no leaks, bodywork/metalwork is something I can actually do - unlike, say, tune an engine.
  10. hogfiddles
    Ok... Be very careful with gas-impregnated metal though!!!!
  11. Old_Ironsights
    Riverton WY
    ;) worked on quite a few automotive gas tanks back in the day...
  12. k-moe
    People are more scared if welding gas tanks than is warranted. Every tale or experience I've had with fuel tank explosions turns out to be a problem with the prep work and technique. Caution and adherence to a thorough cleaning is something that people tend to skip because it takes so much time to do well.
  13. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Besides, explosions only happen when rapid expansion meets a sealed container. Don't seal up the tank while you're working on it and the worst that can happen is it makes a big "whoosh" sound and flames shoot out of it. Wear protective gear, like you should be at all times (even though I admit to breaking that rule more often than I should), and you will be fine.
    Famous last words.
  14. Old_Ironsights
    Riverton WY
    I'm doing to gravel-polish the inside and strip the outside before I decide what else needs to be done - whether to re-paint and install, weld on it or junk it. It will be a good bit before I have to worry about adding heat.
  15. Kyute
    Kyute New Member
    Fort McMurray, Alberta, Canada
    Nifty idea. Too bad my next nearest gas is almost 200 miles away and it'd make little difference. Still, cool mod.
