Charging problem no charge at idle. Charge above that
Discussion in 'XJ Technical Chat' started by bomber737, May 10, 2015.
  1. bomber737
    bomber737 Member
    New Richmond WI
    I was servicing my girlfriend's 83 xj750 Maxim. I have a voltmeter wired in so I can keep an eye on the charging system. I just put a new agm battery in it that was fully charged. When instated the bike I noticed it was only putting out 11.5 volts so I know it was running on the battery. When I revved the bike up it started charging. I took it out for a ride and the voltage held steady at 14.2 volts. Once back at idle it went back to 11.5 again. I took the alternator cover and checked the brushes and they look good. Both are the same length. I also cleaned up the donuts for with some scotchbright. I reinstalled the cover and fired it back up and still discharging at idle. Anyone have any thoughts?. New voltage regulator?
  2. k-moe
    What you are seeing is normal. The alternator does not spin fast enough to deliver 14.2 volts until you reach 2,000 RPM.
  3. bomber737
    bomber737 Member
    New Richmond WI
    Ok Ill check it out. I had to unhook the tach as it was causing me electrical issues and blowing the main fuse. I took it out of the system and no more fuse problem. I just seem to remember that it did charge when it was at idle. I think is was like 13.1 volts. I guess well see wht happens with some more riding.
  4. XJ550H
    no there is no charge going on at idle your running off the battery, I checked mine the other day.same results as what you are stating.
  5. bomber737
    bomber737 Member
    New Richmond WI
    Great, I guess she will have to have her limit her warm up time so she doesnt run her battery down.
  6. XJ550H
    how long does she need to warm it up? could start riding with Partial " choke" once your moving shut it off
  7. bomber737
    bomber737 Member
    New Richmond WI
    Probably 5 minutes while she puts on her helmet and her golves. Maby a few min longer when its cold out. The bike is off choke in about 3 minutes. I colortuned the idle mixture screws and I usually check (adjust) the sync every spring so I know they are set up for the summer riding season.
  8. Polock
    just because their not charging the battery doesn't mean that they run off the battery. the bike is still making juice, just not enough to charge the battery.
    it can idle and not charge the battery till the engine overheats. Be more concerned with over heating
  9. hogfiddles
    ....and unless its really hot out, you're not gonna overheat anyway. Besides, you're gonna be RIDING the bike----fast. You're not gonna spend all your time sitting on the bike at idle.
    Dave
