Easy tire change with zip ties.
Discussion in 'XJ DIY How-To Instructions' started by razz1969, May 13, 2015.
  1. razz1969
    razz1969 Active Member
    Cleveland, Tx
    Don't know if this has been posted before or not. He makes it look so easy, wonder how many off camera takes did he do.
  2. Polock
    this is a perfect example of why you shouldn't believe everything on youtube
  3. k-moe
    I prefer the $40 at the shop method.
    NEEDtoRIDE likes this.
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I like how he says he'll be doing it with zip ties and his bare hands, and then proceeds to use a bead removing tool. Bead breaking tool? whatever. Oh yeah, and a pry bar too!
    Also, is anyone else wondering what kind of damage a hard plastic zip tie could do to the bead on those tires?
  5. Polock
    Zip ties won't hurt the bead but that bead breaker will and that tire iron with cardboard is childish.
  6. Taku
    Taku Active Member
    Morganston, Ontario
    Wow, I could've changed 5 tires by the time he had those zip ties on. No need for a bead breaker either, a jack-all is all I've ever used.
    Just changed a rear tire on the XJ700 a few minutes ago, getting the old tire off and the new one on took about 4 or 5 minutes. Tubeless tires are easy. An MX tire with a tube on a rusty rim with two rim locks...different story.
