Turn signal relay - cold?
Discussion in 'XJ Technical Chat' started by dmlyster, May 18, 2015.
  1. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Just recently I've notices that my signal relay does not function when first running bike (prior to solid warm-up) and again when riding in cooler weather ( 60 deg F or less).
    Turn signal works when held in position but as it slides back to center position it shuts down the signal. However, when riding in 65 deg F plus temperatures it functions perfectly.
    Any thoughts on the relay? I know ........ I know .. ...... just ride during warm weather!
  2. k-moe
    The factory signal relay has a removable cover. Take the cover off and clean it just as you would clean a points ignition system. See if that helps. You may also want to clean all of the electrical contacts in the switchgear, and the wiring harness (clean the bulb sockets as well). It sounds to me like you may have enough resistance from corrosion to have a large voltage drop when it is cold out, and possibly a battery that is on its way out.
  3. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thanks K! That helps a bunch, now I know it should not do that and a path forward.
  4. Vampirum
    Vampirum New Member
    Sudbury, ON, Canada
    Did k-moe's suggestion fix your problem? I'm having the same issue here.
  5. dmlyster
    dmlyster Member
    Corvallis, Oregon
    I've not yet disassembled yet ..... so, cleaning should fix but likely won't know until riding time slows down and I get the courage to tear into the thing.
    Dale
  6. k-moe
    It takes maybe ten minutes and if you mess it up a generic replacement is $4 at any autoparts store ( you will lose the self canceling with a non yamaha relay)
  7. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thanks K. Seems every machine screw on my bike is seized (or so it seems) ..... so I will need 24 hrs plus the 10 minutes :)
    Hopefully your comment will help Vampirum in the short term ..... I think I will wait until I start getting cold weather again.
    Thanks again!
  8. k-moe
    The relay is on the frame under the fuel tank. No screws need to be removed to access it, or ot take it apart.
  9. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Ahhhh .... I thought it was part of the thumb actuated controller. I'll continue to explore.
  10. k-moe
    I lied. The Maxim tank might be held down by a bolt (the 650 is, not sure about the 750).
  11. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Yep, the 750 does have a bolt for the tank :) it was the first one I removed and the only one that was not seized. I documented your lie (that was not a lie) so that some day when I do a half lie we will be even.
    Thanks again for the direction.
