Ignition switch wiring queston
Discussion in 'XJ Technical Chat' started by madbones, May 25, 2015.
  1. madbones
    madbones New Member
    australia
    Ok so i have my stock wiring loom that i have pretty much fitted and have come to the ignition switch connector. Now a while back i jumped on a new key switch that was a decent price as my old switch would intermittently seize and not turn. Ive just realized the new switch plug is a three pin connector verses the original four pin ( three pin -Brown, Red, Blue , four pin- Brown, Red, Blue, Blue red stripe ) . obviously the plugs are not compatible but.............if i were to get a new plug to match is there a way i can utilize the three wire switch.
    Id appreciate and electrically minded brains ideas and thoughts.
    there is a thread in how to's on fixing the switch, do you still have the original switch? it is real easy .
    would also have to know what bike you have
    http://www.xj4ever.com/clean and lube the ignition switch.pdf
    three wires on my xj550 also same on 650
    red comes from main fuse
    blue goes to tail light
    brown goes back to fuses
    got a wiring diagram?
  3. XJ550H
    you could combine two wires into one connector in a 3 pin socket.
    this will put more stress on the wire going from the connector to the switch.
    but without knowing what your extra wire is for and its amp needs you may cause your self problems and end up buying a new switch.
    you would be better off running a fused wire from your battery
    with a switch on it to the "extra" wire.
    need a wire diagram to say what your wires do.
  4. CapnRedbeard
    CapnRedbeard Member
    London England
    Similar colour coding on my xj750uk. Red traces back to main fuse, Brown also traces back to fuse block but serves head light and signals
    Blue feeds light switch and control panel lamps. Blue /red serves licence plate and parking light .
    I also have two red/white wires but these serve battery sensor and cockpit battery warning light.
  5. XJ550H
    if as suggested by CapnRedbeard it is your tail light and plate light run a wire and switch to it with inline fuse from battery to the connector.
    just remember to shut it off.
  6. madbones
    madbones New Member
    australia
    Yep thought it might not be that simple. Ive sourced a four pin switch to save the headaches.
    Thanks to everyone for our helpful input.
