LED Lighting (again)
Discussion in 'XJ Modifications' started by IronHD, May 26, 2015.
  1. IronHD
    IronHD New Member
    Charlotte MI
    Hey all, like so many others I'm converting to LED signals and tail lights. I've read (and printed) SQL's tutorial on the process. But....I really don't want to dig into my PC board (XJ1100 maxim, 1982). So, can anyone tell me what value of resistor I need to add inline on my tail lights to fake out the monitoring system?
    Thanks!
  2. k-moe
    You need a total draw of 27 watts on each bulb. To figure out a load resistor rating you will first need to know the wattage of the LED assembly you are using and the current rating. After that it's just simple math. Here is a link to a calcualtor that will help you. http://www.csgnetwork.com/ohmslaw2.html
    Alternatively you can just buy a pair of load resistors like these, and wire one per side, mounting them where they will get airflow and not contact anything that will melt.
    IronHD likes this.
  3. Polock
    http://ledcalc.com/#calc
    supply, use 13 volts
    Voltage Drop Across LED, if these were made for a bike use 12 volts
    Desired LED Current, it should say this on the package someplace in milliamps
    How many leds connected, 1
    you need 4 resistors, one for each light
    IronHD likes this.
  4. IronHD
    IronHD New Member
    Charlotte MI
    Thanks guys! I'm planning on just putting in the LED replacement bulbs to maintain the stock assembly. So I guess I need to put the loads on both the tail and brake circuit sides of the bulb. Thanks again for the links and help!
  5. Polock
    the tail and brake lights, you can just put the led bulb in and go. the reason for the load resistors on the turn signals is to make the stock flasher and cancel system work.
    if you don't care about the auto cancel, then you get a led flasher and forget the load resistors
  6. IronHD
    IronHD New Member
    Charlotte MI
    I was only going to use the load resistors so I didn't have the monitoring system constantly telling me my bulb was burned out. That'll work right?
  7. IronHD
    IronHD New Member
    Charlotte MI
    Also, on this bike the front signals are dual filament running/turn so I'm thinking I'll need to have load resistors on the running light circuit to defeat the monitor.
  8. Polock
    to tell the truth, it's been so long since i've had that monitor system i don't know. the resistors will make the flasher and auto cancel happy. does it monitor the turn signals too?
  9. IronHD
    IronHD New Member
    Charlotte MI
    Oh, nope. Only monitors the tail. My bad, disregard.
  10. Polock
    my bad, i guess you do need resistors on the brake and tail lights
