Don't try this at home....
Discussion in 'Hangout Lounge' started by Wirehairs, May 25, 2015.
  1. Wirehairs
    Wirehairs Member
    St. Paul, MN
  2. k-moe
    I don't see the problem. Spiked tires on ice handle better than sticky tires on asphalt.
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Hot damn, that GT3 looks like fun. How many hundred thousand? I'll take it!
    Toomanybikes likes this.
  4. mwhite74
    mwhite74 Member
    Wow, and when he's done scraping his knees he could have a game of Hockey!
  5. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    -25 c (-13 degF) !!?! Don't think my XJ would even start at those temps or keep running... then again not sure I would either :p lol
  6. Toomanybikes
    Tsawwassen bc
    Never mind that you would have 1/4" ball bearings in your pants
  7. Mad_Bohemian
    Ravenna MI
    o_O
    Pretty sure at those temps they would migrate north into my body cavity!!:p
  8. Toomanybikes
    Tsawwassen bc
    They might approach absolute zero where all motion stops
  9. Drew
    Drew New Member
    Cambridge Ontario
    My record is -30C on my Ural. But then again I have full winter gear including heated hand grips.
  10. Toomanybikes
    Tsawwassen bc
    Is that a Ural with a sidecar? Cause tires don't stick well at that temp.
  11. k-moe
    Ural tires don't stick well at any temp.
  12. Drew
    Drew New Member
    Cambridge Ontario
    In the winter I use dirt bike tires which are a softer rubber and do stick.
