front wheel torque
Discussion in 'XJ Technical Chat' started by Tony7745, Jun 2, 2015.
  1. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    I removed my front wheel to paint it. When I put it back together I go to torque the wheel it keeps drawing the rotor towards the inside of the fork. I loosed it up to evenly space it and to put the cotter pin in. The wheel is evenally spacer but the but is not at its proper torque. What should I do ?
  2. Ribo
    Ribo Prefectionist
    Which bike do you have? Sounds to me like you're missing a spacer.
  3. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    81 Xj650. I do have the spacer between the right fork and wheel.
  4. Ribo
    Ribo Prefectionist
    how about a picture?
  5. Rooster53
    North, FL
    Are you following the procedure in the FSM?
    Install axle and tighten to 77.4 ft-lbs, install a new cotter pin
    Install the front fender
    Compress the forks several times to verify operation
    Tighten the axle pinch bolt to 14.5 ft-lbs
    And, after install, pump the front brake several times and release - verify drag is not excessive when rotating front wheel
    A picture would be good as Ribo suggested just to be sure we understand what you are describing.
  6. k-moe
    Did you put the speedometer drive back on the left side?
  7. Ribo
    Ribo Prefectionist
    ^^^^ that's kinda what i was thinking too but a picture is worth 1000 words.
  8. Toomanybikes
    Tsawwassen bc
    Yea that thing dangling by the cable up against head pipes not included in parts pile on floor
    The kind of thing that happens when your working on your bike at 1am after kids and wife in bed
  9. hogfiddles
    Tighten the pinch bolt LAST..... If you do that first, you'll have all kinds of problems....
  10. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    I have a FSM and when I tighen the axle nut to toque the wheel walks to the left edge and the rotor begins to run on the inner fork. I'm an auto mechanic and I assume you torque the nut with the front tire on the ground. Then tighten the pintch bolt...etc. I included pictures.
  11. Ribo
    Ribo Prefectionist
    I'm not seeing anything obvious here - I'm assuming that's the spacer on the oposite side to the disk in the photo and not the axle.
    Here are the same shots of mine that i recently removed to replace the tires etc.
    Sounds to me just from a physics perspective that when you tighten the nut there's some space between it and the other side of the bike that is allowing you to tighten it too much cos there's nothing to stop it. did you check the wheel bearings haven't fallen out or the internal spacer - At this point I would take it off and start pulling it apart and accounting for everything show in this picture from the haynes manual.
    Edit: Just re-reading your post - I'm not a mechanic but i would think that torquing the nut with the wheel on the ground could be an issue if there is some miss-alignment and the wheel needs to seat itself correctly. I could be wrong but I would think it better to allow everything to freely-ish move to come together. When I did mine I did have the wheel on the ground but most of the weight was taken by a jack between the pipes.
  12. Toomanybikes
    Tsawwassen bc
    Tony did you replace wheel bearings during repaint?
  13. k-moe
    It looks to me like you may not have the pinch bolt out when you are tightening the axle nut. The pinch bolt side has to be completey slack so the fork tube does not hang up on the axle. If it does hang up you can use a rubber mallet to gently persuade the fork leg back over to the left. The fork leg should contact the spacer. You may need to loosen the fneder bolts also. The fender has a fork brace and that can also keep the fork legs from aligning correctly if it is tight.
  14. hogfiddles
    And we'll keep saying that, too... Lol
  15. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    I'm going to take it back apart after work. I didn't remove the wheel bearing at all and the seal on the left side is even with the fork. So, I should lift up the bike again and remove the fender. Remove the axle and assemble as such: fork, spacer, wheel, speedo housing, fork. Tighened for to spec even though it draws the whole wheel over to the left side fork where the rotor is. Lower the lift, Jounst the front forms then tighen the pinch bolt.
  16. Polock
    look at Ribo's second picture. the brake disk fits over a lip on the wheel. The silver part just to the left of the speedo drive. Is yours like that? hard to tell in the pic
    PS. i tighten the pinch bolt first, then the axle nut, then loosen the pinch bolt, smack it around a bit, bounce the forks, then tighten again. So really i tighten it first and last.
  17. k-moe
    The fender doesn't have to come off. Just loosen the mounting bolts.
  18. Ribo
    Ribo Prefectionist
    If something is happening WITH tension that doesn't feel right don't continue. Something isn't seated right here. Did you grease the axle? maybe that's catching on the internal spacer? Take a look at it too and make sure there's no nic's and that it's 100% straight.
    Tap the axle all the way through as far as you can with a rubber mallet before adding the nut.
  19. Toomanybikes
    Tsawwassen bc
    Only 5 things will make the rotor touch the fork
    1 too much paint or powder coat moving disc over
    2 failed wheel bearing
    3 speedo drive internal sleeve worn due to bad wheel bearing
    4 inner hole in wheel worn due to bad wheel bearing
    5 wrong brake rotor
  20. Ribo
    Ribo Prefectionist
  21. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Hey, don't knock Giorgio! His hair is from outer space! I love how "scientific" all the Ancient Astronaut Theorists can sound! Sorry for the sidetrack, but that is the funniest show on tv!
  22. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    Well I think I figured it out after taking it apart again. The inner spacer between the two wheel bearings is laying on its side and not in line with the bearings. I guess its time to remove the seal and bearing to make sure that spacer is parallel with the bearing so the axle can sit it all three.
  23. Toomanybikes
    Tsawwassen bc
    There are 2pieces inside main spacer and flange spacer to keep main spacer in line make sure that is there
    KirkRJ likes this.
  24. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    She is fixed ! Once the inner spacer was in the right location, it torqued up fine. I have been riding it for the past 3 days. Now, my turn signals done work. Fuse is good, switch is clean....etc. I must do some electrical diagnosis.
