82' 750 Maxim Rejetted?
Discussion in 'XJ Modifications' started by Mike66, Jun 4, 2015.
  1. Mike66
    Mike66 New Member
    Ft. Lauderdale
    I have removed the original air box and have added 4 individual air filters/(pods). What is necessary for optimal performance in regards to the Carbs?? Do I need to rejet, if so I need help moving forward. I'm more of a fabricator than a mechanic.
  2. k-moe
    For optimum performance put the airbox back on.
    Josh phillips and Beekman like this.
  3. Mike66
    Mike66 New Member
    Ft. Lauderdale
    That's what I figured. I already modified the frame by lowering the seat and took up that space.
  4. k-moe
    OK then . Start by using the airbox boots between the carbs and the pods. They are velocity stacks and will help performance. After that you will probably still be lean. Do yo still have the stock exhaust?
  5. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    I couldn't fit the boots and the pods. Will that make a major issue?
  6. Polock
    can you push the boots up in the pods to make the whole assembly shorter? the carbs like the air flow that the boots make.
  7. Mike66
    Mike66 New Member
    Ft. Lauderdale
    To K-Moe, I have the original exhaust from the head to the manifold. I plan to modify it some how or purchase the 4 into one exhaust for it.
  8. MarkV
    MarkV Member
    Vermont
  9. k-moe
    OK that will help some with the jetting. Fitting the airbox boots hlps even more; good to see that you can.
    I'd start out on stock jets with that configuration and see where you are before changing jets.
  10. MarkV
    MarkV Member
    Vermont
    It's a struggle, but they go.
  11. MarkV
    MarkV Member
    Vermont
    Only jets I changed were the mains. Brought them up to. 126.
