My '80 XJ650 .....
Discussion in 'XJ Modifications' started by XXWoodmanXX, Jun 6, 2015.
  1. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    So, I picked up a 1980 XJ650 with 15K on it, in-trade for my starter D-SLR Canon camera (roughly $425) :)
    At the time, she wasn't running because the PO did a starter rebuild, and turns out he clocked the magnet/brushes wrong when he re-assembled it all back together. Took me about an hr to figure it out and I had her running!! :D
    Here's what she looked like when I got her:
    Other issues she had were:
    - Carbs flooded intermittently
    - Carbs needed cleaned
    - Bolts rusted everywhere
    - Front brakes needed replaced
    - Coils fired when they felt like it (which was rarely!)
    - Exhaust leaks at head
    - Plugs desperately needed replaced, as well as plug wires
    - Most elec. connectors were corroded
    - Rear shocks were shot
    - Front forks needed rebuilt/filled
    I fixed all of the above issues and did a few changes of my own to make her feel "mine". :D
    And now here's how she looks today:
    Some changes were:
    - Chopped welded straightpipes down and removed resonators/baffles
    - Jetted carbs to 118/41 @ 3.5 turns
    - UNI pod filters
    - FZR600 master cylinder/mount
    - KLR650 Clutch perch
    - chopped rear frame
    - Nitrogen rear shocks w/ progressive springs
    - '97 Katana 600 coils/plug wires
    - TL1000S rear brake light assembly
    - ProTaper 7/8" bar
    - Chopped/re-fitted front seat (not the best, but I love it)
    - Re-fitted license plate mount on axle clamp
    - Yamaha R1 Rectifier/Regulator.
    - re-painted wheels
    She runs gorgeous, and I'm totally in-love. :D I get all sorts of compliments, and friends are anxious as to what I will do next to her. My love for bikes went from 'doddling-around', to hobby, to my passion.
  2. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Tried messing around with an old brake disc off of my 94 FZR600r. Had to put 9mm of spacers behind it, but it stops great,
    If i had to guess, i probably saved 4-5 lbs by swapping out the stock disc
    Should i worry about going from a heavy, solid disc to a lightweight, floating disc.
    BaldWonder likes this.
  3. k-moe
    The disc swap should be fine as long as the spacers are solid and the bolts held with thread lock (I notice you don't have any safety wire or locking tabs). You should put the front fender back on, or at the very least take the section that has the fork brace and bolt that on. It really is a necessary part of the assembly.
    I have a question. Why is your right shock surrendering?
  4. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    It knew too much. I promised that, should it forfeit the alphanumeric combo of my license plate, the consequences would be severe. :D
    and yes, i've been looking into how i would like to chop the fender before the re-install.
    i also plan on replacing the TL1000 brake light. I was anxious to get her road-worthy ;)
  5. Ribo
    Ribo Prefectionist
    Nice bike man.
    Is the disk custom or where did you get it?
  6. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Stock pull-off. Just gave it a shot of gold and mounted right up. The 6-bolt pattern and diameter matches perfectly. Only difference was thickness.
  7. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Just ordered a clutch perch & mirror off an '08 KLR 650.
  8. Ribo
    Ribo Prefectionist
    Stock from what?
  9. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    1994 Yamaha FZR 600r
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Ribo... you're slipping!
  11. Yamaha33410
    Yamaha33410 New Member
    West Palm Beach
    I really like your handlebar setup, What kind of dimensions are on that particular bar? I'm still on the fence as to what handlebars to use exactly
  12. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    What did you use for spacers on the brake disc. I'm tempted to follow suit. Someone drilled a hole in mine and filled it with magnets and JBWeld!
    MattiThundrrr likes this.
  13. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Here is the specs on the handlebar I have:
    Part: Superbike Handlebar 7/8in Black Emgo 23-12571
    Color: Black
    Bar Diameter: 7/8 Inch
    Bar Width: 29 Inches
    Bar Rise: 2-1/2 Inches
    Bar Pullback: 4-3/4 Inches
    Bar Center Width: 4-3/4 Inches
    And remember, your right switch housing is grounded THRU the stock chrome handlebar. If you replace it with a painted bar, and don't run a seperate ground wire to chassis (or grind down to bare metal on bar mount and switch housing area), your bike will not start.
    As for the brake disc mounting, I used 8 or 9mm of machined zinc alloy spacers. Just ensure that the wheel's surface and the inside of the brake disc mating surface is clean,so you don't have any uneven braking.
    WARNING: You will need to machine/dremel the wheel speed gearbox to make it work with this setup. Or have a cap and spacer machined to replace the wheel speed gearbox.
    OR, just buy one of these :D
    http://www.ebay.com/itm/Yamaha-XS65...?fits=Make:Yamaha&hash=item27eaeb5646&vxp=mtr
    Yamaha33410 likes this.
  14. MattiThundrrr
    Effin' POs. He he he...
  15. BaldWonder
    Oberlin, OH
    Like custom machined, or is this something common you can buy that I just don't know about?
    I'm thinking I won't need the modified wheel speed gearbox, since I'm sporting a magnet and reed switch setup with a digital speedo. But that's cool that there's one like that available.
  16. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    I got my spacers at my local ACE hardware. I'm sure they can be found at any Lowe's or HomeDepot, too.
    Titanium header wrap came in the mail lastnight. Can't wait to put it on this weekend :D
  17. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Got a little done to the bike this weekend (a hot one out today!)
    - flipped rear shocks
    - replaced clutch & mirror perch with an '08 KLR 650's
    - custom-cut and painted front fender and mounted it up
    - wrapped headers in Titanium lava wrap :D
  18. k-moe
    Did you soak the wrap in water first? It loks a little loose.
    Fender looks pretty good.
  19. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Yup, soaked it. Its pretty tight, i just overlapped more than i should have. Half tempted to get some black 2500-degree header paint and spray it down.
  20. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    FINALLY fixed my blinker issue. The solder points in the left control module completely seperated from the PCB board itself. I replaced it with a '96 FZR 600R left control housing alltogether. Turned out perfect, after soldering pin-to-pin. :)
  21. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Btw,... I used 4" led strips wrapped around the shocks.
  22. hogfiddles
    Some nice things going on there..... I'd like to see the seat shaped differently though.. It's very obvious it's just a stock seat " that's been cut in half". I think you can do much more and not look like a "typical springer/bobber type seat"
  23. BaldWonder
    Oberlin, OH
    Agreed. It's been killing me, too, but I know not everyone has, or is comfortable using, a sewing machine.
    The lights are cool. I assumed at first they were electroluminescent tape. Did you get them from chromeglow.com?
  24. MattiThundrrr
    Yeah, those LED strips caught my eye. Had to look at the other unlit side to figure it out. Looks super custom! Nice work. Have to agree with Dave about the seat. Perhaps rounding the cut on the pan and cutting away some of the excess material on the cover could bring the seat to the next level. Awesome looking bike, though! Constructive criticism, not hurtful! Keep it up!
  25. BaldWonder
    Oberlin, OH
    I'll clarify: I only mean constructive criticism, too. If the rest of the bike weren't so nicely done, the state of the seat cover wouldn't stand out as much. I'm just trying to say that it would be a relatively "easy" way to score a bunch of points. I realize just how not easy it can be, though.
  26. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    Thx all. Yea, I rushed the seat for sure. I have more ideas on what I want to do with it. Will keep u guys updated. :)
  27. saftie
    New York, NY
    Cool. Have you tried dropping the headlight by an inch or so?
  28. hogfiddles
    take a look at my pseudo-modified 700 in the showcase. Consider altering a 700 seat sort of like I did. You'll get the same support width, and length, but it will give more 'flow' to the visual line.
    Dave F
  29. MattiThundrrr
    I shouldn't criticize... Like BaldWonder said, I am afraid of sewing. Also nervous about staple guns. Instead of recovering my seat, I bought another used seat for like 60 bucks. It has little pin holes in it. You get what you put in to it... Maybe I'll use the extra one as a learning tool. Maybe I'm the learning tool!
