Rear shock stud end repair
Discussion in 'XJ DIY How-To Instructions' started by hogfiddles, Jun 9, 2015.
  1. hogfiddles
    My 650rj has a case of broken shock mount threads. A Previous Owner had snapped off the threaded parts of the upper shock mounts on both sides. His solution to keep the shocks from coming off was to weld them in place. Needless to say, now they couldn't pivot, plus they were actually weaker as the top rings were compromised.
    It took some time to figure out the solution. I wanted to stay as original as possible, maintain strength, and use factory equipment. The studs are no longer available, and I was not a out to try extracting ones from another frame, and then have to extract these, and still have to weld ones I to the holes.
    So, here's my fix-- for those of you who have similar issues, I can now supply you with these parts!!
    I let the pics speak for themselves, other than captions:
    ---Here we go
    Starting time
    The problem
    Grind threads flush to stud
    Center punch
  2. hogfiddles
    Step through drill bit sizes until desired hole is drilled
    Tap the hole-- I used a regular tap, then a "bottoming tap" (shown)
    The magic part!!
    Installed with a couple locked nuts to torque it into place. Use RED locktite
    All better
    Roast644 likes this.
  3. hogfiddles
    Add the washer, standing handle, acorn nut
    Look at the clock-- only one hour!!
    The only things I used: hearing protection/eye protection, grinder and dremel, center punch, drill and bits, taps, wrenches, and red locktite.
    If anyone needs new ends for doing this project, contact me and I can have a set made for you!
    Dave Fox
  4. bubba650
    bubba650 Member
    Miami
    Great write up and good work! A++
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Ok, pictures make this perfectly clear. I get it now, but I still have 2 questions.
    1. How did you ensure that the hole you drilled was going in straight on,
    2. How many sissy bars do you have hanging on the wall there?
    The legend of your parts hoard grows...
  6. k-moe
    This is one way. [​IMG]
    The V shaped sliding part is a tool to find the center of any round stock. Ther are other types of center-finders, and some are pretty easy to make at home.
  7. MattiThundrrr
    That is a cool square. A lot of these fabricating tools are very new to me. Finding the center I get, but I still can't visualize what Dave would be doing to ensure that the hole goes in straight. There is not much there to place the square against, and a bunch of obstacles around it too. I don't have any real need for this info, my shock mounts are fine. However, since I am new to this, I want to learn as much as I can from others, so when a problem arises, I'll be ready! Someday, I'll have to learn about the electrical stuff too. I read the posts, but my eyes glaze over and my mind wanders... Thanks to all who have taught me!
  8. hogfiddles
    Well..... I drill slowly and carefully--- I stop and check every several seconds carefully to make sure the drill is staying in a straight line from the side, and I can easily see if it stays in a straight line from the top.
    In short, if | and __ are straight, then the + will be straight.
    How did I make sure it was centered? I used my ruler and marked halfway, both horizontal center line and vertical center line.
  9. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Nicely done, Dave. This makes a lot more sense than your other, picture-less post that preceded this one, but what in the holy hell is that thing? (And don't say it's magic!)
  10. BaldWonder
    Oberlin, OH
    Actually, looking at it more now: is it just a regular threaded rod that got lathed to a narrower diameter on one end, then tapped/died to the desired thread?
    I realize you may have explained that in the other post already, but I'm too forgetful and too lazy to find your post and re-read.
  11. hogfiddles
    Yes, but go to your Local hardware store and ask for a step-stud that is:
    M10x1.25px14mm/m8x1.25px8mm and They will have no clue, tell you it's a wrong size, and tell you it's not available, and it's the wrong one, or it'll have to be custom-made, etc...
  12. PuskRat
    PuskRat New Member
    Canton Illinois
    I like that. Clean. Quick (relatively) and non-destructive (i.e. un-doable)
  13. AliMac
    AliMac New Member
    Dover
    Excellent solution - very helpful write up - many thanks
  14. hogfiddles
    Thanks!hopefully it helps someone:)
  15. Franz
    Franz Well-Known Member
    Scotland UK.
    Great repair Hogfiddles.
  16. kboehringer
    kboehringer Active Member
    Peachtree City, Georgia
    Very Very Nice Repair.... Great work!!!
    Every time I THINK I've seen the stupidest backyard repair, I get to see yet another. The P.O.'s welding that shock is definitely in my top ten of dumb arse repairs I've seen on these old bikes.
  17. hogfiddles
    Thanks!!
    Yeah, I wish I had taken a close-up of the shock while it was still welded on the post! I do have a couple pics of it when first got it.... I'll have to see if its visible on those----
  18. MattiThundrrr
    I await the results...
  19. hogfiddles
  20. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    A thing of beauty!
  21. chacal
    We now have that stud available for others who need to do this type of repair:
    HCP28443 Aftermarket shock absorber UPPER MOUNING STUD REPAIR KIT. This threaded stud (and installation tools) allow you to repair a common problem: the upper shock mount threaded studies hopelessly damaged or broken off completely. Kit includes a special, step-down threaded stud, proper size drill bit and thread tap, locking fluid, and complete illustrated instructions. A great view of how and what this repair kit does can be seen at: https://www.xjbikes.com/forums/threads/rear-shock-stud-end-repair.62848 Note that we also have the step-down stud available by itself, so if you already have the tools (or need to repair more than one stud) you don’t have to purchase the rest of the kit contents a second time. Will work on all XJ550, XJ650, XJ700, XJ750, XK900, XJ1100, and XS1100 models….and many other bikes which use traditional rear shock absorbers, and which use an M10 x 1.25 thread-pitch nut on the shock threaded stud.
    HCP28443STUD Aftermarket shock absorber UPPER MOUNING STUD ONLY. Of course this is included in the above kit, but if you need additional studs (for additional repairs), then it is also available separate
  22. hogfiddles
    Very nice :)
