Jet Placement
Discussion in 'XJ Technical Chat' started by WeRobBanks, Jul 2, 2015.
  1. WeRobBanks
    WeRobBanks New Member
    Fairborn, OH
    Hi, I took both jets out of the top of each carburetor, and don't remember which jet goes in which hole. It looks like there is a 210 and a 70 for each one(they are difficult to read, so they might be other numbers). One has a pretty big hole, and the other has a much smaller hole. (I'm new to this). Does anyone know which goes in which hole? There are three holes in a line in a trench like shape- two are threaded and one is not. So is the 270 for the threaded one on the end or in the middle of the three? I can take a picture if you don't know what I mean.
  2. k-moe
    Pay no attention to the jet sized in the photo; it's from a different model of XJ.
    The cover was not used on later machines, so it that hole will be left empty.
    Next time, take pictures before you take something apart.
    Also note that the service manual has these jets mislabeled as to position.
  3. WeRobBanks
    Fairborn, OH
    I thought the bigger jet was the main jet and the smaller was the pilot...
  4. Toomanybikes
    Tsawwassen bc
    Easy way to remember
    Little jet near little screw
    Bigger jet bigger distance from screw
    Same with signal wires
    Yamaha green has the "right" of way
    Honda are there any oranges "left"
  5. lush90
    lush90 Member
    Outside of Seattle
    Very clever!
  6. Polock
    good, now remember that's backwards
    if you shoot carb cleaner in the big air jet it comes out the small fuel jet
  7. chacal
    Sort of a dead giveaway there, I rather prefer to remember by mneomics, but that's problee cuz I wuz hooked on phonics......
    Stumplifter likes this.
  8. Toomanybikes
    Tsawwassen bc
    Hooked on something ??
  9. chacal
    Right!
  10. Toomanybikes
    Tsawwassen bc
    Oh yea bikes!
  11. Skwerly
    Skwerly Member
    Yucaipa, CA
    Sweet info!
