carb float pin
Discussion in 'XJ Technical Chat' started by mattdillon, Jul 3, 2015.
  1. mattdillon
    mattdillon New Member
    Jemison, Alabama
    Hi guys I'm in the process of building a bobber out of my xj550. When I started to try to get her to run I decided I needed to clean the carbs. Upon removal of the bowl I find that someone has been in there before me and left me a little surprise. Anyway to the point. Apparently they lost one of the float pins and replaced it with a piece of mechanics wire. So my question is can I find one out of a spare carb as long as it's the same length and diameter. Sorry for such a long post and I hope I explained it good enough to understand. Thanks in advance.
  2. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    absolutely....one out of a spare carb is better than mechanics wire....
  3. chacal
    We do have them available new (Mikuni float pins, not paper clips).
  4. Luis
    Luis Member
    Seacoast NH
    Fiveofakind, please listen to chacal (Len), he will have anything and everything you will every bed for your bike
  5. Luis
    Luis Member
    Seacoast NH
    Replace (bed) with (need)... Damn spell check
  6. fiveofakind
    San Diego, CA
    Luis,
    I dont need anything for my bike ( runs great ).....but MattDillon does.......& Chacal is the man.....
  7. Luis
    Luis Member
    Seacoast NH
    Opps, sorry fiveofakind, my bad...
  8. mattdillon
    Jemison, Alabama
    Thanks for the replies guys. Will any pin out of a spare carb work or will I need a specific carb? How much are new ones chacal?
  9. k-moe
    A pin out of any same-make carb will work.
  10. chacal
    All of the Mikuni pins are the same, which are different from the Hitachi pins.......
  11. mattdillon
    Jemison, Alabama
    https://www.mikesxs.net/product/20-6503.html
    Will this pin work? I haven't found one for an xj550 yet. I've found floats with pins for xj600s-750s. I'm gonna try a local bike shop before I go and order one off the internet. But will one out of other model and size xj series bike work? Thanks for your help guys. I hope the link works.
