Revisiting: new tank for a 85 maxim 700 x
Discussion in 'XJ Modifications' started by chevybythesea, Jul 19, 2007.
  1. chevybythesea
    chevybythesea Member
    Are there any bigger tanks for this bike? This one is dinky (in the 3 gal. range)
  2. ajclockga
    ajclockga Member
    Commerce Ga
    Try mine 2.5 gal.I commute about 500 miles a week.I spend more time at the gas station than home.
  3. chevybythesea
    I am getting about 100 miles per tank, not counting reserve, which seems to be wierd, as in not working....
  4. Kishkumen
    Kishkumen Member
    Bowling Green, KY
    No, 100 per tank (not using reserve) sounds right. Dunno about larger tanks, though.
  5. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    With a little fabrication..... anything can/will fit!! But, I'm assuming your searching for the easy bolt on solution.... for that I don't know!
  6. chevybythesea
    Yes, I was looking to see what would just slap into there....Probably nothing!
