Turn signals, brake light, neutral light, tach and others not working
Discussion in 'XJ Technical Chat' started by Jimbo55, Jul 6, 2015.
  1. Jimbo55
    Jimbo55 New Member
    Atlanta
    I have a 1985 xj700 N Maxim. I was replacing a burned out hi beam indicator light and all of of a sudden I realized that my neutral light, blinkers, and brake light didn't work at all. The electric tachometer didn't work either except when the kickstand was down and it was in gear (kick stand kill switch didn't work either) I checked for loose connections and found none. I have also replaced the main flasher relay, that didn't work either. Everything else on the bike works fine. I don't know wtf is going on. Somebody please help!!!!!
  2. Rooster53
    North, FL
    The brake light, neutral light, blinkers, horn, and tach are all powered by a 15 amp flasher fuse. Have you verified it is not blown?
  3. Jimbo55
    Jimbo55 New Member
    Atlanta
    Is it one of the ones inside the indicator light panel?
  4. Jimbo55
    Jimbo55 New Member
    Atlanta
    Ding ding ding. We have a winner folks. Thank you so much. One of the fuse clips was bad. It's fixed now.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Rooster saves the day AGAIN!! and this time his post didn't make my head spin!
  6. Mustang
    Mustang Member
    Masonville
    How bout this one try to use the horn or any brake switch and the cluster shuts off any turns back on, I know its a shot is there a normal spot to start looking? I've combed a bunch of wires and shook them around but can't find it
  7. Rooster53
    North, FL
    Do the blinkers cause the same issue? Brake and horns are both fairly high current as are the blinkers. If it's voltage drop from a poor connection the blinkers may not function. May not be a short, but a poor connection at the fuse (signal or flasher depending on bike) or a defective fuse. Inspect the fuse holder closely to verify it is not burnt, corroded or broken, and maybe just try another fuse.
    Edit: noticed new member post, what bike is this?
  8. Mustang
    Mustang Member
    Masonville
    1981 xj750r seca, I put in a mini fuse holder 3000 miles ago with no problem, first fuse blew last week and second one 2 days ago, bike still runs good , just noticed the reset deal yesterday, turn signals also reset everything but I don't use them, missing the front 2 lights so no flash but all rear lights come on and headlamp functions like it should
  9. Rooster53
    North, FL
    Can you relate that to a particular event, such as applying the brakes? And to be sure it is a 10 amp signal fuse that is blowing?
    Is the lighting cycling or is it the computer monitoring system that recycles as in a check system command or power up command, or both?
    I noticed from one of your earlier post that the main harness was a bit of a mess from the PO and some of the safety circuits were bypassed - even some bike shutting down when shifting if the instrument cluster was connected? Depending on how bad it is you may want to consider replacing it as they can be acquired fairly cheap.
    If it is currently not blowing fuses you could pull the signal fuse and place a DMM in current mode across the fuse. Normal signal circuit current is less than 1 amp until applying the brakes, enabling the flashers, or honking the horn. If that is normal the you could test the remainder of the signal circuits for correct current. Brake lights should add about 3 amps, turn signals are about 3 amps, and the horn is at least a couple of amps. There is a bit of a risk to your meter, but most are protected with a 10 amp fuse.
  10. k-moe
    At some point it becomes a good move to buy a used harness that has not been hacked up.
  11. Mustang
    Mustang Member
    Masonville
    It's the whole check cycle, when I press brakes, turn signal or horn. 10a fuse does blow I removed some sort of safety relay 3000 miles roughly 2months ago but this just happened last weekend
  12. Mustang
    Mustang Member
    Masonville
    I haven't done anything else since then, does any one have a good wiring diagram I can't find one for my bike its always a different year with odd wire colors or for a different motor
  13. Mustang
    Mustang Member
    Masonville
    I guess my check button is stuck down bit it has been like that since I got it I figured it was a light or something
  14. Mustang
    Mustang Member
    Masonville
    I'm planning on getting a round speedometer and tach so I will be eliminating the factory gauge cluster are there wires I can just cut out and remove from the bike?
  15. Mustang
    Mustang Member
    Masonville
    I fixed it, don't know what I did but I fixed it.
  16. Bighappy
    Bighappy Member
    Kingston, Ontario
    Just had this happen as well.....is the fuse in the block under the seat?
  17. Bighappy
    Bighappy Member
    Kingston, Ontario
    Can anyone tell me where this 15A fuse is located??
  18. Bighappy
    Bighappy Member
    Kingston, Ontario
    Anyone???
  19. MattiThundrrr
    Bighappy. did you mention which bike your working on? If you start a thread with your problem in the title, and mention which bike, you might get more help. My XJ750 has the fusebox under the seat.
