Drive Shaft Oil
Discussion in 'XJ Technical Chat' started by apfenech, Jul 9, 2015.
  1. apfenech
    apfenech New Member
    Utah
    I have a 81 XJ 750 Maxim (probably an 82 titled early - though it is a rebuild). The guy I'm borrowing it from mentioned that he wanted to do the drive shaft oil. I tried to find something here about that but have been unable.
    Is there such a thing as changing drive shaft oil? How would I go about doing that?
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    There recently was a post about this.
    Try doing a Google search . . . Type in XJBikes and Final Drive Oil.
    For some reason the search engine here isn't as streamlined as we would hope for.
  3. nickbrit16
    nickbrit16 Member
    Ohio
    Yeah, it's located on the "pumpkin" on the rear left side of the bike. You'll see a nut on the top rear side. Not the vent on the top (round looking thing, don't touch it). Loosen the top nut and then loosen the nut on the bottom. Drain and fill just like a basic oil change. Fill only to edge of fill hole. Be sure to use a "Hypoid Gear oil 80w90. I change mine after riding for about 5-10 mins to get the oil hot so it drains faster, but that's just my personal preference. Hope this helps.
    Stumplifter likes this.
  4. apfenech
    apfenech New Member
    Utah
    Perfect, thank you. I'll start using the Google search instead of the one on the site. I appreciate the help!
  5. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    the manual recommends you change the gear oil with every oil change
  6. k-moe
    But you don't really have to with the better gear oils we have available to us. The GL-4 gear oils that were originally used on our machines were in the transitionary period when lead had been removed from gear oil, but the sulphur additives of GL-5 caused our final drives more harm than good. I'm still giving some thought to what the change schedule for GL-5 should be, but every other oil change should be a conservative schedule. I may just send mine off for testing the next time I change it to see what's happpened to it over the past 6,000 miles.
  7. slackard
    slackard Active Member
    Earth, Terran System
  8. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Either will work.
  9. DenCon509
    DenCon509 Member
    Central Washington, USA
    I am using Redline MTL - my research indicates no risks.
  10. k-moe
    No real benefit either. It's great in manual transmissions though.
  11. Jerrod Robinson1086
    Jerrod Robinson1086 Member
    Marion Ohio
    Hey Guy's, I just Replaced a Seal in my final Drive and I'm having some trouble. Is there a Specific Pattern that you have to Bolt everything back together in or something? When I put it all back together it's not Seazing, but it's not spinning like it should. Anyone know what I'm doing Wrong?
