What to use for broken tab on plastic side cover?
Discussion in 'XJ Technical Chat' started by HAFROD, Jul 16, 2015.
  1. HAFROD
    HAFROD New Member
    Claremore, OKLAHOMA
    I did a search and it found nothing for TAB. I need to reattach the tab on the plastic side cover. It seems like every year there are better and newer epoxies. Every one I have tried has broken back off even with both surfaces roughed up and clean. Any success stories or info on what to use?
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    I drill a small hole near where the tab has broken off and then run a cable tie, or zip tie whatever you call them, through the hole and then through the location point and pull up to secure. If ever you need to remove just cut off and then re-apply. Can be a bit tricky sometimes but you'll never lose the cover if it comes loose.
  3. HAFROD
    HAFROD New Member
    Claremore, OKLAHOMA
    I'm doing a restoration so the zip tie thing aint gonna work.
  4. Polock
    the covers are ABS so use ABS pipe glue. get all that epoxy off then cut a piece of ABS pipe and catch the "saw dust" mix that with some glue to make it thicker and build it up a little.
    glue it first with a little straight glue first then use the "dusted" glue to build it up. the thicker glue will take longer to dry, should be stronger than new
    rocs82650 and BaldWonder like this.
  5. HAFROD
    HAFROD New Member
    Claremore, OKLAHOMA
    I went to my automotive paint store and bought 2 part multi plastic epoxy. It was $40. I put it on some cracks in my fairing and the tab. It stayed rubbery so this wont work. I knew I should have got quick set 50. Took 2 minutes to put it on and 15 minutes to remove it. Its what the store owner said would work.
  6. Polock
    what's quick set 50?
  7. HAFROD
    HAFROD New Member
    Claremore, OKLAHOMA
  8. a100man
    a100man Well-Known Member
    Bedford, UK
    Or ABS glue like Polock said. We call it 'solvent weld'. Plumbers use it to join waste pipe. It gooey and does the job well - use sparingly though.
