Fuel lines xj750j
Discussion in 'XJ Technical Chat' started by Jeffb18618, Jul 17, 2015.
  1. Jeffb18618
    Jeffb18618 New Member
    Pennsylvania
    On mine main line goes to carb and other smaller one goes to each (4) carb boots. Is this correct?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Yes, bigger fuel hose to carbs rack. Smaller vacuum hose to one of the four carb vacuum ports (it's usually #3). The unused vacuum ports should have a cap/clamp combination installed.
    Gary H.
  3. Jeffb18618
    Pennsylvania
    Not all 4. Thats what I have.. bought it recently
  4. k-moe
    You should only have one fuel line on your carbs. I think that either you have a different XJ than you think you do, or you have carbs from a later XJ (or a different bike entirely).
  5. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    what bike are you talking about.......yr, make & model.....???? post in your signature....
    if you are talking '82 XJ750J Maxim........you have 1 fuel line coming off petcock to fuel rail inlet between carb body #1 & #2 and the vacuum line from petcock to vacuum port on #2 carb.......#1, #3, #4 vacuum ports are capped off with rubber caps with clamps.....
  6. k-moe
    Just thinking out loud, but he might have a later Canadian xj750, which would put him in the era of the emissions "octapus"
    Jeffb18618 likes this.
  7. fiveofakind
    San Diego, CA
    newbie without a signature.......should be a requirement before first post.....
    Luis and Stumplifter like this.
  8. Jeffb18618
    Pennsylvania
    Sorry about being so vauge. Yes 1982 xj750j. As far as the newbie statment you can keep that to yourself. This is my second xj750. If you would like my entire riding history from 1979 to present please forward your email to me.
    thank you
  9. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Jeff, what fiveofakind is saying is that many of the members here put their bike in their signature and bold or highlight it. Then there is no confusion as to which model is in question.
    He isn't snubbing you, he is pointing out an issue that has been present on this site for some time now. And you ARE a 'newbie' here, at least in regards to your number of posts.
    I personally have given incorrect advice to others based on my experience with an XJ650 Maxim and ass-u-ming that the details were transferable to any model XJ . . . . They aren't (always, sometimes).
    We want to help, there is a lot of smart people here (five is one of them) and our intent is to have the best community on the World Wide Web.
    Luis and Jeffb18618 like this.
  10. k-moe
    1982 xj750J. A Maxim. Post up a pic of your carbs, because there should only be a single fuel line and no vent lines that year.
    Do they look like this?
    The above are carbs from an xj900, which have larger carb throats than the XJ750 carbs. You can use them, but it would require a rejet and you might not get optimum performance even then. The fuel line is the one on the left in this photo (yours may have the fuel line on the right depending on which XJ900 they came from). The small lines are float bowl vents (they don't hook to anything) and the other big one is for the emissions canister (IIRC).
    Do me a favor and check the shorty VIN on the engine. You might have an engine transplant.
  11. fiveofakind
    San Diego, CA
    Jeffb18618,
    I am sorry if you took my post the wrong way.......my sarcastic sense of humor.....as Stumplifter indicated, numerous newbie's will ask questions without us knowing what year or model.....
    if you have an 1982 XJ750J Maxim or Seca, with stock carbs, then you should only have one fuel line & one vacuum line coming off petcock..... the other 3 vacuum ports are plugged off with vacuum caps.....
    If your carbs look like above, then someone has changed out the original carbs...............
    Hey, my name is Jeff B ...originally from York, PA.....
    Hope you have a great day.....
    I am the original owner of my 1982 XJ750J Maxim for over 30 yrs now.....so I am very familiar with this yr & model.....and have done alot of reading and listening on this site.......numerous members have helped me along the way with my 2 yr restoration of my bike ......and many thanks to them......these bikes require a lot of time, patience, and money ( sometimes ).......
    bigfitz52 ( have not seen him nor heard from him ) & k-moe and others who I have failed to mention offer some of the best advice here on this forum.....
  12. Polock
    Jeff, your petcock should have one fuel line towards the front and one vacuum line in back. vacuum line goes to any handy vacuum port on the intake tubes and the other 3 are capped.
    PA, eh. Pirates or Phillies, Flyers or Pens ?
  13. fiveofakind
    San Diego, CA
    JeffB,
    You thought I was bad, you will enjoy Polock's sense of humor......I have over the years.....he is funny.....
  14. rocs82650
    Middle Tennessee
    I'm thinking like k-moe...maybe he has a different rack on it.
    +1 what five said.
    @Polock: Royals and Predators.:)
    Gary H.
    Luis likes this.
  15. fiveofakind
    San Diego, CA
    His initial post indicates that he is talking about which carb boot does the smaller line off the petcock go to ? I am assuming he has a stock 1982 XJ750J carb rack.....which would mean there are no float bowl vents to worry about....
  16. rocs82650
    Middle Tennessee
    That's what my first reply implied then things got distorted even after several other members replied the same thing. We're asking to determine whether the rack is stock.
    Gary H.
  17. fiveofakind
    San Diego, CA
    I would say JeffB needs to pipe in & be more specific as to his carb rack.....& by what he means by "each of the (4) carb boots"
  18. Jeffb18618
    Pennsylvania
  19. Jeffb18618
    Pennsylvania
    sorry to be a douche eariler, i appreciate any help i can get...also have question about going to pod filters after the time i had removing the airbox...oh yea a bolt in for 33yrs ,,,only broke 2, lucky it was the bottom ones on 2 and 3
  20. Jeffb18618
    Pennsylvania
  21. Jeffb18618
    Pennsylvania
  22. Jeffb18618
    Pennsylvania
    thinking about the pod filters for this...... my theory is its easier for carbs to get air, but air is still regulated by carbs..or is this incorrect?
  23. Jeffb18618
    Pennsylvania
    original issue was running extremely hot,,lean? idle for 15 min. and gas boils in tank..hot
  24. fiveofakind
    San Diego, CA
    what you have there is a stock 1982 XJ75oJ Maxim......exactly like my bike.....your Vin # starts with a 15R - XXXXXXX
    heads up....pods equal problems....keep it stock.......unless you want to screw around with re-jetting......still might have major problems....once you get her all fixed up....she will look like this......i can help you along the way as well as others.......
    that carb rack is stock for that bike.......
    My bike......when they are dialed in......they are a sweet ride......what part of Pa. are you from.....??? My bike was similar to yours.....I was quilty of owner neglect for a # of years.....but with time, patience & money...and free advice here....I was able to get her running again.
    BigT and Jeffb18618 like this.
  25. fiveofakind
    San Diego, CA
    sorry you snapped thelower intake manifold bolts on carb #2 & #3.......be careful on extracting them out......on re-install.....use anti-seize compoumd.....
    Looking at pics of your bike.......the only things that I see that are not stock is your mirrors and your rear taillights ( they should be rectangular like your front ones ). other than that......you definitely have an 1982 XJ750J Maxim....they are sweet machines.....
    Do you have a factory shop manual for this bike.....???? or Haynes ???
  26. Jeffb18618
    Pennsylvania
    nepa, scranton/wilkes barre area of pa....MANUAL?,,, we dont need no stink'in manual.. my bike was left outside for a long time before i bought it.
  27. Jeffb18618
    Pennsylvania
    san diego? i did time at 32nd street and point loma, lived in chula vista & mira mesa camped at otay valley lake{in a uhaul} hahahaa
  28. fiveofakind
    San Diego, CA
    I am from York, PA.....moved to Colorado in '81 , bought bike in '82 & have had it since.....moved in San Diego in '85 & have been here since......I come back every year to Pa. for deer hunting... alot of fun....
    Were you in the navy or working the shipyards....
    Anyway, a factory service manual would be helpful for you....private message me in this forum & I can help you with that
  29. Jeffb18618
    Pennsylvania
    frustration set in last night, sweating like a whore in church. today is take a break, 92 degree forcast, by the pool. tonight is check the carb bowls and clean. this week heat and extract the bolts and replace..still waiting for boot gaskets to manifold anyway.
  30. Jeffb18618
    Pennsylvania
  31. fiveofakind
    San Diego, CA
  32. fiveofakind
    San Diego, CA
    Jeffb,
    Check your inbox......I sent you a message.....
  33. Polock
    Those bolts are not going to be fun.
    Don't make a bad situation worse.
    Luis likes this.
  34. Luis
    Luis Member
    Seacoast NH
    +1 polock, been there, done that... It turned out to be a bear!!
    jeffb 18618... 10 years USN FF1051 AND FF1086, I lived down in IB, right down on the beach, loved it, second boat pearl harbour Hawaii.. San Diego is where I bought my first bike 1982.... Don't need to say it again but the guys on the site are some smart sonsofbitches... They just blow my mind about these bikes:)
  35. Luis
    Luis Member
    Seacoast NH
    And your gonna love polock:) :) :)
  36. k-moe
    If you're intent on working without a manual, please put the bike up for sale before you turn it into scrap.
  37. hogfiddles
    The big line goes from the petcock to the carbs: the small line goes from the petcock to ONE of the vacuum ports----
    doesn't matter which one; the other three get caps on them.... Dont try to split the vacuum line four ways.
  38. rocs82650
    Middle Tennessee
    In the first pic of your carbs:
    The hooked bracket attached to the left side of the #1 hat is for the fuel line. The thin hooked bracket on #2 is for the vacuum hose. They're routing brackets.
    Gary H.
  39. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    You sure the thin one is for a vacuum hose?
    That one has always been holding my clutch cable.
    Nevermind. I seen the even thinner one on the later pics. I'll just slink back into my hole.....
  40. rocs82650
    Middle Tennessee
    Lol.
  41. Jeffb18618
    Pennsylvania
    B4 I turn it to scrap? Ive been wrenching for many years. I'll part it out before I scrap..lolol
  42. k-moe
    Then you already know the value of having a service manual handy.
    There are plenty of model-specific procedures that just can't be guessed at, and that do not respond well to the usual rules of thumb.
  43. Toomanybikes
    Tsawwassen bc
    As far as I remember we never had multi hose crap on our bikes
  44. k-moe
    Apparently on my phone California (when spelled incorrectly) gets corrected to Canadian.
    Toomanybikes likes this.
  45. Toomanybikes
    Tsawwassen bc
    Gotta love that... Subliminal adds for Canadian tourism!!
    Have you checked the weather up here is nuts hottest summer in 60+ years but we are on level 3 water restrictions. No car washing no lawn watering. Shutting down kids water play parks. Average May to August rainfall is 4-5" per month we are less than 1/4 " . Big panic over low river levels affect on salmon runs
  46. fiveofakind
    San Diego, CA
    no service manual = self defeating
  47. Jeffb18618
    Pennsylvania
    Broken bolts were frozen. Drilled and tapped from 6 to 8mm. Carbs cleaned. I'm replacing all the boot bolts. Assemble tomorrow. Freaking work...id be riding by now
  48. fiveofakind
    San Diego, CA
    you are going to need patience with these bikes......and a service manual.......see your inbox for message....need address for CD mailing...
  49. chacal
    The 1984 XJ750RL models used the HSC33 carbs, same as 1985-86 XJ700 airheads, and they do have a bunch of extra hose crap on them!
    So should the XJ900's. which k-moe pictured on the first page of this thread.
  50. Jeffb18618
    Pennsylvania
    Ok all assembled. All clamps are tight. Battery at 12v. Key on. Push the start button and all I get is the solinoid clicking. .....what now.?
