SOS My power suddenly cut out!
Discussion in 'XJ Technical Chat' started by JS13, Jul 28, 2015.
  1. JS13
    JS13 New Member
    new jersey
    I have a 1981 xj550 maxim that was running great until this afternoon. I had the choke on warming it up but when I closed the choke the bike died and the neutral light went out. The starter still spins when I hit the starter button but no lights or flashers come on now. I checked my side stand switch and fuses but everything looks fine. I am stuck at work until I figure this out. Any help is greatly appreciated!
    have you tried starting the bike side stand up?
    if your neutral switch has failed you can connect it lead to ground it is located under the front sprocket cover you will have to remove the cover to get to it.
    you will have to loosen the passanger foot peg to remove cover 10 mm wrench for the shifter bolt, i forget which allen wrench you will need.
    you can also try unpluging the relay under the seat this will bypass the neutral light and sidestand switch THE STARTER CIRCUIT RELAY UNDER THE SEAT FRONT OF BIKE disables the rest of the safety switches and clutch safety switch he neutral light.
    you may have to clutch start it with this relay out
    edit for relays
  3. JS13
    JS13 New Member
    new jersey
    Thanks for the reply! I had the kick stand up when it happened, I never took it out of neutral when it happened. I will try unplugging the relay and see if that works.
  4. XJ550H
  5. JS13
    JS13 New Member
    new jersey
    I tried unplugging the relay with no luck. I pulled and jiggled the plunger on the side stand switch out but it still didn't do anything. I'm stumped as to why it would happen from closing the choke? I've never had a problem like this in the 3 months I've had it
  6. XJ550H
    reread my pos t there is another relay .
    you do mean shuting off the "choke"
  7. JS13
    JS13 New Member
    new jersey
    I'm going to try that out and yes I mean shutting off the choke to warm it up. It fired right up this morning and even right before it happened.
  8. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Bump start it and get home then diagnose the problem. You'll drain the battery if you don't.
    Gary H
  9. JS13
    JS13 New Member
    new jersey
    I tried bump starting it with no luck, it's acting as if the key isn't in. Could it possibly be the ignition switch? I have tried everything that's been suggested here so far and appreciate all the replies!
  10. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Got spark? Maybe a fuse blew randomly at just the right time?
    I realize you checked fuses. But you never know... I don't trust my eyes. I use a DMM to test continuity.
  11. XJ550H
    are you getting voltage at the 3 other fuses?
    main fuse goes to key then back to the fuse block.
    there is a connector under the tank square and black it is the connector that brings voltage to the key.
    do you have a manual ?
  12. Rooster53
    North, FL
    No brake light, horn, or signals indicates a problem with the signal circuit, either a blown fuse or excessive load just under the rated amps. Just maybe when the choke was pushed off a short was created on the incoming Br/W wire at the left hand control. Check the signal fuse again (is it hot), and if it is not blown, pull it out and try to start the bike with it removed.
    If the fuse was hot or you have drained the battery a bit another push start attempt may be in order if the battery has degraded enough to affect starting.
    Note: WAG since the signal circuit on a stock bike would normally not affect starting.
  13. Toomanybikes
    Tsawwassen bc
    Even a loose battery cable ,but ign contacts in switch will do that, very common in old Hondas more than with yamahas .
  14. JS13
    JS13 New Member
    new jersey
    I'm getting 12.5v on the battery but nothing anywhere else?
  15. k-moe
    Even at the main fuse in the fusebox?
    Check that fuse with an ohm-meter, and check for voltage on both sides of the fuse.
    Does the bike have the original fuse block?
    Luis likes this.
  16. JS13
    JS13 New Member
    new jersey
    yeah I'm getting nothing anywhere on the fuse block. It is the original stock fuse block
  17. JS13
    JS13 New Member
    new jersey
    I replaced the main fuse even though it looked fine and it fired right up! I feel like a dumby but couldn't be more appreciative of all the responses I got! Looks like it's time for a new fuse block and a manual
    rocs82650 and k-moe like this.
  18. rocs82650
    Middle Tennessee
    You're not dumb...you're learning. I'm learning new stuff all the time.
    Gary H.
    Stumplifter and JS13 like this.
  19. k-moe
  20. schmuckaholic
    California
    That's why you run a continuity check with the meter. I got bit by that one personal-like.
    Years ago I was trying to be come a radio repairman with the Marines; part of the classwork was troubleshooting equipment in the lab that already had a known problem. One such unit had no power. Step one; check the fuse. Hmmm, looks good...
    ...nope. Fuse was broken down near the end cap where it couldn't be seen.
    Now, if you check the old fuse later and it passes, then there's an issue with the fuse block -- and since you're dealing with that, you'll have one less thing to worry about.
    When you email Len, ask for HCP378BC - that's the fuse holder, complete with required fuses. Or, if you want the fuses to "glow" when they blow, try item number HCP378LF.
    As for the service manual, HCP1094 is for the Clymer, and HCP1128 is for the Yamaha factory manual. Ask about pricing and availability.
