Clutch moves but doesn't work
Discussion in 'XJ Technical Chat' started by newbike91, Jul 25, 2013.
  1. newbike91
    newbike91 Member
    South Haven, MI
    Hi guys. Long story short I changed my clutch cable only to put the old one back on. However, no the little lever down on the motor moves like normal, but the clutch doesnt work. Also, it doesnt have enough force to pulle back and return to its normal position. Could it have become disconected inside somehow?
  2. bigfitz52
    Nope. It's trapped and can't really disengage. But it might have got spun around or jumped teeth and needs to be re-oriented.
    There is a little 'pip' on the case and a mark in the "butt" of the little lever. When the lever is pushed forward (in the direction the cable pulls it) by hand, it should stop with those marks aligned.
    If it doesn't, then remove the clip and back the lever up a couple of splines until it stops with the marks aligned. Then re-attach the cable and adjust.
    The "starting point" for the cable pulling the throwout lever is when the lever stops when being pushed by hand; those little marks need to be lined up at that point.
    If that's not it then possibly there is something wrong inside. But if it worked beforehand, I suspect it's just throwout lever positioning is all.
  3. newbike91
    newbike91 Member
    South Haven, MI
    Ok I'll take a look at that. Thank you sir.
  4. RickCoMatic
    First, ... Rotate the Free-play out of the Clutch ROD extending down into the Case.
    Wrap a Shoelace around the ROD -- ( Like a Pull Starter ) -- Pull-out the Slack.
    Tape it to the Case while you Adjust the Cable and Throw-out ARM.
    Minimum Throw:
    Illustrated in accompanying photo.
  5. bikeboy929
    bikeboy929 Member
    mahtomedi, mn
    make sure you have the bolt in the lever that sits on the pole into the clutch, no bolt and it will slip and jump, if not back it like they said
  6. bigfitz52
    There is no "bolt" in/on the throwout lever. It is held onto the shaft by a c-clip.
  7. newbike91
    newbike91 Member
    South Haven, MI
    Not sure if that's the problem. I can move it up till it stops by hand and it still doesn't work.
  8. bigfitz52
    OK. Move it until it stops by hand. THEN attach/adjust the cable so that the "stops by hand" position is the starting position for the cable pulling on it.
  9. newbike91
    newbike91 Member
    South Haven, MI
    Ok, I see what you are saying, and excuse my ignorance, but if it wont go further by hand how will it move with the cable?
  10. bigfitz52
    Because your hand does not have enough "mechanical advantage" at the stubby little lever to lift the pressure plate off the pack against the springs. Even with a pair of pliers, it is nearly impossible.
    The lever/cable DOES have the necessary mechanical advantage.
  11. apezman07
    apezman07 New Member
    Canton, OH
    this is more or less an issue of trial and error...put the lever on, if bike doesnt move, adjust lever 1 tooth forward, and so on till bike moves. you are supposed to line up the marks, then adjust the nuts where the cable is bracketed on. may need to adjust the clutch hand lever as well.
  12. adrian1
    adrian1 Active Member
  13. Haapala
    Haapala Member
    WA-USA
    Running into the same issue...I understand what I need to do to fix it, but I can't figure out how to reposition the throwout lever. Can someone explain it in more detail?
  14. Luis
    Luis Member
    Seacoast NH
  15. Haapala
    Haapala Member
    WA-USA
    Thanks Luis! I had read that before but somehow missed what he was saying. All sorted out now.
  16. Luis
    Luis Member
    Seacoast NH
    good to hear!!:)
