I broke a float post, and other carb issues...
Discussion in 'XJ Technical Chat' started by wombosi, Aug 7, 2015.
  1. wombosi
    wombosi New Member
    Western MA
    so I decided to give me carbs a more thorough cleaning. In the dismantling process I broke off one of the supports that holds the float in! dang. Can this be jbwelded or epoxied?
    also, removing the float needle seats (?) - one of the little filter screens was completely missing, and another was badly clogged. couldn't believe how dirty everything was despite recently boiling in lemon juice (without removing jets).
    lastly, a lot of the jets were badly mangled and had to be vice gripped out.
    does someone on ebay sell a complete replacement kit?
    i had just replaced the float bowl gaskets but they broke apart taking off the bowls. so one more thing to replace!! gaahh
    click this link len is a supporting vendor http://www.xjbikes.com/forums/forums/xj4ever-supporting-vendor.23/
    this is his main site link email is in upper left for quotes http://www.xj4ever.com/ he has what you need
    there is a thread on how to fix your post someplace it will have to be searched for.
    . basicly the fix is to drill a hole in the post and whats left of the post insert a pin.
    lemon juice aint the cure all for cleaning carbs, but you can not use carb dip unless you dissamble the carbs
    Stumplifter and cameronleeharris like this.
  3. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Use an in-line fuel filter and you can get rid of the little screens.
  4. Toomanybikes
    Tsawwassen bc
    Or pick up a used carb. What bike is it and I have some hitachi carbs for spare parts
  5. wombosi
    wombosi New Member
    Western MA
    Thanks.
    It's an 82 Maxim 650. I have no idea if the carbs are Hitachi or Mikuni - doesn't say anywhere on them.
    There are a few jets I'd like to replace but don't even know what they are. I'll try to find a diagram.
    Thanks for the link to Len's site.
  6. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    They are Hitachi carbs, if they're the originals.
  7. k-moe
    And it does say on them. There is a stylized H cast into the carb bodies (one side, centered on the slide bore), and HSC32 anodized/inked onto the bottom side of each float bowl (the anodizing/inking may be faded).
