Redone Valves, Rough Running
Discussion in 'XJ Technical Chat' started by xjyamaha, Jul 25, 2007.
  1. xjyamaha
    xjyamaha Member
    Omaha, NE
    Just got done putting in my new valve shims, and reassembled. I had a hell of a time getting the thing started and after a little starting fluid, she fired up finally but is running pretty rough.
    I has more of a chug sound now than it did before and is a lot more deep sounding, but i can't get it to idle, it only runs when the throttle is held open.
    I did the finger compression test on all cylinders and every cylinder would push my finger from the sparkplug hole. Did i do something wrong, overlook something maybe?
    thanks
  2. samsr
    samsr Member
    Colorado Springs
    Now it is time to sync the carbsand adjust the pilot mixture. New plugs would also help.
  3. xjyamaha
    xjyamaha Member
    Omaha, NE
    well i synched the butterfly valves, readjusted the float levels, set the mixture screws to 3 turns out and still no go. The bike hardly starts and with the help of a squirt of ether, bad i know, it fires but runs pretty bad.
    It will not idle, and when warmed idles for a minute then dies. Sounds choppy and when riding from about 2k - 4k RPM's it has poor throttle response and kind of cuts out, but sitting still in nuetral it has no problem revving. Above 2k -4k it acts alright. I also noticed a ticking sound coming from cylinder 4 area.
    The bike ran pretty well before this and the carbs were cleaned 7 times prior, that's no exaggeration. I checked the metering holes or whatever those little holes are in the float bowls and they are fine, and the float needles and diaphrams move easily.
    I am considering taking it to the local dealership, i feel i have wasted alot of time on this bike and it has made little improvement. How bad do stealerships rape you? Any other advice?
  4. MiCarl
    I'd do a compression test to make sure there wasn't a major mistake on the shim job.
    If that's ok then I'd look for what got messed up in the fuel system when I had the tank off to do the valves.
  5. samsr
    samsr Member
    Colorado Springs
    plug wires in the correct position?
  6. RickCoMatic
    Check the TIMING MARKS with Number 1 at Top Dead Center!
    I want to hear that you are on the Marks and the Chain is TIGHT!
    What are the Clearances 1 ~ 4 on BOTH sides after the Shim Job?
    Let's get that out of the way before we dig in to what happened.
    Right now ... what we have to Go on is:
    "Shims Happened and it's possible to lose timing!
    Don't be running that bike until we get to the Bottom of this.
    If you're out of TIMING ...
    That ain't a good thing!
  7. xjyamaha
    xjyamaha Member
    Omaha, NE
    i just took it a couple miles down the highway and noticed that when in gear 5, it wont go above 5k RPMs. It feels like it's chugging and cant go any faster, But on 1 - 4 i has pretty decent acceleration. Plug wires are fine, all the plugs are about a year old and are gapped correctly. If i had a compression tester, i'd test it
  8. RickCoMatic
    Park it!
  9. xjyamaha
    xjyamaha Member
    Omaha, NE
    mechanic? i'm not ready for a $400 bill
  10. RickCoMatic
    Goto
    Your Private Messages
  11. SalCycle
    SalCycle Member
    vancouver, bc, Canada
    Hey, are shims a stock item in at the dealer?
  12. RickCoMatic
    Shims are a Stock Item.
    There are plenty of Bike's that all use the same Diameter Shims.
    You don't need the Dealer.
  13. SalCycle
    SalCycle Member
    Regarding the dealer: Rick, but then I'd have to order them, I assume.
  14. RickCoMatic
    You can walk-in and pick-em-up at the Dealer.
    My last visit was just last week for Shims. I couldn't wait.
    3 Shims for $15.00.
    I could have got a deal if I needed 4.
    I could have got four ... for only 20-Bucks!
  15. Robert
    Possibly got the timing chain marks out of time???
  16. xjyamaha
    xjyamaha Member
    Omaha, NE
    nailed it on the head, i came in for a cold one and had a quick question, i got the cam chain tension out and the chain is loose but i just can't quite slide it off the sprocket to adjust the camshafts individually, is there a way to do this without taking the caps off?
