Will my stator short???
Discussion in 'XJ Technical Chat' started by Alex mathieu, Aug 29, 2015.
  1. Alex mathieu
    Alex mathieu Member
    griffin ga
    I have a 1985 Yamaha Maxim Xj700, I'm planning on installing a phone charger/ usb. this being a older bike Will it fry my stator?
  2. k-moe
    It will not. You won't be drawing more than 2 amps, and the charging system can handle that.
  3. Alex mathieu
    Alex mathieu Member
    griffin ga
    So no damage whatsoever? You don't think I need to put in a fuse holder with a 5 amp or lower fuse, or is that even feasible?
  4. XJ550H
    if you hook it directly to your battery put a fuse on it because that is good practice.
    you could save yourself some wattage if you replace your tail and lic plate lights with led bulbs,you could also replace your instrument cluster bulbs as well, these bulbs are always on .
  5. k-moe
    You should always put a fuse into any circuit. The fuse prevents a fire from occurring when there is a dead short.
    rocs82650 likes this.
  6. Alex mathieu
    Alex mathieu Member
    griffin ga
    Thank you all!
  7. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If you have a battery charger pig tail installed couldn't you just plug into that? Mine already has a fuse and that's how I plan to plug in a gps if I ever decide to take a long trip on my XJ700,
