Post for float pin broke off, suggestions pls?
Discussion in 'XJ Technical Chat' started by kalyekid, Aug 31, 2015.
  1. kalyekid
    kalyekid New Member
    du quoin, il
    one of the posts for the pin holding the float was broken off during dissambly, any suggestions please.
    Thanks. Harold
    1982 xj650 maxim
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    You can try epoxy to reattach, but it may fail and cause you grief late on down the road. Try and find a replacement carb body, make sure you get the correct carb as they are all a little different, not just bike to bike but the correct carb body for that cylinder.
    kalyekid likes this.
  3. XJ550H
    there is a thread in the forums on post repair
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    There are a few ways to repair. I good machinist should be able to drill it and pin it back together.
    A drill press and a machinist vise would be needed.
  5. jason191918
    jason191918 Member
    Weston, WI
    mine is held on with marine jb weld.
  6. kalyekid
    kalyekid New Member
    du quoin, il
    Thank you. I have been looking in ebay, but an old carb costs a lot in there and no guarantees it will work. Thus I am exploring for other options. Have a nice day.
  7. kalyekid
    kalyekid New Member
    du quoin, il
    Definitely will try this. Thank you very much.
  8. kalyekid
    kalyekid New Member
    du quoin, il
    Thank you. I saw it. It definitely would be the best for my situation. I will try to find the tools needed or someone who could do it for me around here. Thank you.
  9. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Best option......buy another rack of carbs......that way....you have plenty of extra parts........post repairs.....may or may not work....why take that chance.....just buy another individual carb if you find from a member here
