How to start a old Yamaha
Discussion in 'Hangout Lounge' started by Polock, Aug 23, 2015.
  1. Polock
    Easy as pie, just watch this guy
  2. BigT
    BigT Active Member
    Airville, Pa
    What bike was that?
  3. k-moe
    FZ750
    BigT likes this.
  4. BigT
    BigT Active Member
    Airville, Pa
    They sold those in the States in 85?
  5. k-moe
    Yes; from '85 - '88. It was replaced in the U.S. by the FZR600 in '89, but sold elsewhere until '91.
    The Maxim-X is the sister of the FZ750.
  6. BigT
    BigT Active Member
    Airville, Pa
    I noticed the cylinders were leaned forward towards the forks and was wondering the reason?
    Johnius likes this.
  7. k-moe
    More compact packaging, better airflow through the cylinders, and more weight on the front tire. Modern sports bikes have taken that further by also rotating the transmission forward, and stacking the gears above one-another. The design also allows for a larger and more efficient air box, which boosts power production by taking advantage of the intake pulsing to help draw in a bit more fuel and air. There was also a mass-centralization movement going on at the time. getting the CG lower was part of the purpose of tilting the cylinders forward. The goal was to increase the turn-in rate and help the bike to have the same handling characteristics regardless of how much fuel was in the tank.
    Johnius, quebecois59 and BigT like this.
  8. XJ550H
    liked the vertical carb setup.
  9. Toomanybikes
    Tsawwassen bc
    Check out the 80's mullet on the guy standing behind the bikes lol!
  10. pygmy_goat_
    pygmy_goat_ Member
    Exeter, NH
    Wait you need two schoolchildren to start a Yamaha? I've only been using one...
  11. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    but you make up for it with a surplus of goats!
    I always liked in BigFitz's posts how his "Shop Assistant" looks like a twelve year old kid. Can't wait 'til my "Assistant" is old enough to help out!
