Where does this go?
Discussion in 'XJ Technical Chat' started by Johnny And June, Sep 8, 2015.
  1. Johnny And June
    Johnny And June Member
    Mandeville, LA
    Hey guys. I'm looking at my battery tray area and see the negative connection and what looks to be a ground. I don't know where this ground is supposed to go. Can anyone help me out?
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    The ground from the battery goes to the engine case.
  3. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    The thick black wire with the cap is not a ground wire it's the power from the solenoid to the starter.
    Gary H.
  4. XJ550H
    yamaha never heard of red fo:confused:r hot
  5. Johnny And June
    Mandeville, LA
    Got em! I finally got my engine trying to turn over. Now I just gotta figure out these float needles and rejet her
  6. Johnny And June
    Mandeville, LA
    Also what do I do with that black hose in the second picture now that I've removed the air box? does it just come off?
  7. MN-Maxims
    Saint Paul, MN
    Crankcase Vent? Somewhere I saw a small breather that can go on there.
  8. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
  9. Johnny And June
    Mandeville, LA
    What do I do with this? It's completely stripped.
  10. BaldWonder
    Oberlin, OH
    Grind down two sides so you have something you can get a grip on, and replace the whole thing with a spin-on conversion kit from XJ4ever. And as you put things back together, apply anti-seize compound to all the things.
    Stumplifter likes this.
  11. rocs82650
    Middle Tennessee
    It's installed upside down. The letters should be up along with a tab that should recess between two fins.
    Gary H.
  12. XJ550H
    you may need to grind it down all the way if the above sugestion does not work.
    its your oil filter cover if you do not already know.
  13. MN-Maxims
    Saint Paul, MN
    Another candidate for the spin on adaptor. There is a how to video on how to install.
  14. BaldWonder
    Oberlin, OH
  15. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Another option is to cut a slot in the bolt, turning it into a flat head screw. The metal is pretty soft though, (as you have already learned) so it will strip pretty easily too.
    Yaay! Matti's 1000th post!
    BaldWonder likes this.
  16. Toomanybikes
    Tsawwassen bc
    Or get one of these!
