Where this supposed to be pluged?
Discussion in 'XJ Technical Chat' started by Rod1, Sep 11, 2015.
  1. Rod1
    Rod1 Member
    San Luis, Argentina
    Hi again.... taking my gas tank off for new paint... I realized that the plug that it's supposed to be connected somewhere so the "low fuel" light come on is unplugged (wonder why wasn't working!!) so looking around the bike, in the sides and inside I did no see an empty plug where to plug this one coming from the tank...Anyone knows where to plug this end form the tank...
  2. Toomanybikes
    Tsawwassen bc
    2 pin plug? Should be on left side under side cover if I recall.
  3. Rod1
    Rod1 Member
    San Luis, Argentina
    Yes is a two pin plug, but there is nothing there where I can plug this on... I think the "male" plug is missing...
  4. quebecois59
    Mine is under the seat. If the male plug is missing, you may fin two taped "uselss" leads somewhere.
  5. hogfiddles
    Rod1, iirc you have an xj700? If so, the connector is just a little bit behind the back left of the gas tank. The lead comes off off the underside of the tank, goes under the frame, and connects to the harness at the left, pretty much on top of the airbox. If you need a pic, I'll take one. If its a different bike, let us know which one....
  6. Rod1
    Rod1 Member
    San Luis, Argentina
    Hogfiddles mine is a xj 700 1985, send me a pic if is not too much to ask... I checked all around and I didn't find nothing, not even cables be themselves sitting anywhere... The cables coming off from the underside of the tank are long enough to reach under the seat or to the left side plastic cover (if you are sitting on the bike) around that area a didn't see nothing to plug them or like I said any loose leads...
  7. hogfiddles
    I'll do that this evening!
  8. Rod1
    Rod1 Member
    San Luis, Argentina
    Thanks... no hurry...!
  9. RPS
    RPS Member
    North Carolina
    Rod1, here is a pic of the plug connection on my bike. It seems to go directly into the harness. Hope this helps
  10. quebecois59
    Looking at your picture, I remember a post where Bigfitz told us he had his sidestand sticking out like yours without knowing it, he then pushed the bike off of the center stand and the side stand ripped his big toe nail in a flash, because he was wearing some open shoes like yours on the picture. Just saying...
  11. RPS
    RPS Member
    North Carolina
    Ha! Point taken, I was trying to keep my feet out of the picture! Too big I guess!
  12. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    That is my number one garage rule. NO open toe shoes in the garage. Number two rule, the wife can not clean the garage.
    Stumplifter and quebecois59 like this.
  13. hogfiddles
    image.jpg Green/black wire harness should come out at the tail of the tank, and clip into the green/black pigtail clip right along side the airbox snorkel. The tank lead should not wrap around to the outside of the frame, which lead to possible pinched wires. It all stays compact and in the frame.
    Dave F
  14. quebecois59
    Got you ! lol
  15. Rod1
    Rod1 Member
    San Luis, Argentina
    I'll take a closer look at the harness...for sure I do not have a clip coming out from anything...
    I'll like the rule nro 2, lostboy....problem is when it's cold the garage is my living room but she knows after 15 years...she knew me that way....hahahaha....
    Thanks guys I'll try to plug this in and I hope nobody mess with the colors...
