'85 XJ700X No fire on two cylinders
Discussion in 'XJ Technical Chat' started by Gravityisnotmyfriend, Oct 6, 2015.
  1. Gravityisnotmyfriend
    Gravityisnotmyfriend New Member
    Kg*m/S^2, Iowa
    I'm helping a buddy get his bike back on the road after it has sat for a couple of years. We pulled the carb bank and cleaned out all the carbs. They were in pretty good shape. But the CV slides were sticky. All the jets were cleaned and the slides moving like they should when we put them back together. All the diaphragms were in good shape as well.
    It's got spark on all 4 cylinders. All 4 carbs have gas in their float bowls. We got it started on ether, but it would only run on 1 and 3.
    What else could it be? Anything common on these bikes?
    I've started a thread over at ADVrider.com and will probably end up taking the carbs back off. It was suggested that the pilot and enrichment circuits could also be clogged causing issues. It seems to me it should still fire on ether even if those circuit were clogged - but we want this bike running right, so we'll go ahead and dig back in to them.
    Any other advice on what to check would be appreciated.
  2. Gravityisnotmyfriend
    Kg*m/S^2, Iowa
    After a search, looks like I got some reading to do!
    look under plug chops for an explanation of how the 3 circuits work and when in the carbs
    http://www.xjbikes.com/forums/threads/talkin-tech-various-thoughts-on-various-issues.14608/
    the church of clean Must reading
    http://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    naked carbs for understanding the circuits in photos
    http://www.xj4ever.com/inside your carbs.pdf
    and secret life of carbs
    http://www.xjbikes.com/forums/threads/the-secret-life-of-carburetors.14751/
    micheal wade likes this.
  3. quebecois59
    You have a pretty good start with these readings
  4. k-moe
    Welcome aboard!
  5. k-moe
    There is one thing that I think we covered on ADVRider, but I want to be sure of for clarity here.
    Have you swapped the spark plugs around to be sure that all four are firing under compression? If the misfire follows the plugs then it's the plugs that are causing the problem.
    rocs82650 likes this.
  6. CalilforniaBob
    CalilforniaBob New Member
    Los Altos, California USA
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Ditto.
    Gary H.
  8. XJ550H
    the photos do show some info
    Other Mikuni models, like this BS33 from a Maxim-X, move the pilot air jet from under the diaphragm to a passage located in the left side of the carb throat.
    nice little video on the cv carb
    cv carb tuning
    http://www.zrxoa.org/webpages/techinfo/carb/carbtuning.html
