'Vw carburetor on 85 xj700
Discussion in 'XJ Technical Chat' started by hardtailed81/85xj700, Oct 6, 2015.
  1. hardtailed81/85xj700
    hardtailed81/85xj700 New Member
    missouri
    Im attempting a custom carb setup ..single barrel VW carb
    Or a ford single off a 6 cylinder
    ..ive heard it works well if you get the jetting close and choke right..anyone ever attempted this or anything similar. .
    strictly for fun and a cool factor
  2. hardtailed81/85xj700
    missouri
    Im building custom manifold
    4 into one
  3. SQLGuy
    SQLGuy Well-Known Member
    I used a Ford Escort throttle body on mine... took a few tries to build the manifold I wanted, though. Injectors are right up by the ports and angled to fire down towards the intake valves.
    What are you guys doing for the manifold?
  4. hardtailed81/85xj700
    missouri
    Pvc tubing for testing purpose
    I would like to get clear pvc for the final product
    if I can find some gas friendly lol
    its light weight
  5. SQLGuy
    I don't think PVC will take that kind of heat.
  6. SQLGuy
    Also, after a bit of EGR and/or PCV, the inside of clear tubing probably won't be that pretty anymore.
    There are some other plastics that can handle higher heat (obviously, since many new cars have plastic manifolds). PVC starts to break down at 140C/284F. I once tried to use it for part of the coolant loop on a VW Golf. Didn't last long.
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    One member here (orange-n-black) made a pvc manifold for his carb conversion, and it melted due to gas fumes dissolving the plastic. Search for his "Simple carb fix" or something like that.
  8. hardtailed81/85xj700
    missouri
    Ill post a pic of the manifold .
    Almost done..and yes I figured the gas may eat the pvc ...not sure though todays plastics are pretty resistant..?for temperature the pvc part will probly be 6 to 8 inches from the block.m carb is going out one side by the tank and your knee
    wont fit underneath. .thanks for any input all is appreciated
  9. SQLGuy
    What are you doing for the 6 to 8 inches between the block and the manifold? The carb holders are only about 1 inch of that.
    As to gasoline resistance, there is no "today's plastics"... PVC is still PVC. It's rated for moderate effect by gasoline. https://www.google.com/url?sa=t&rct...srUI9uo_ZGvRP7_rA&sig2=_cbpzHlWqSEFlRxAC8e3vg
    If you want to use today's plastics, you need to look for other compounds than PVC.
  10. hardtailed81/85xj700
    missouri
    Right on ..this is really just a test mainly for flow I planned on using rubber hose for the remaining 6-8
    Inches my thought is that I could figure in equal length tubing easier and the manifold wouldnt get as hot
    I have 2inch extensions coming off the carb holders
  11. SQLGuy
    OK. Sounds interesting. Pictures?
  12. hardtailed81/85xj700
    missouri
  13. hardtailed81/85xj700
    missouri
    Hopefully fire it up tomorrow
    see how much scavenging is goin on.
    i may do all copper tubing
    Also have some of this pvc soaking in gas..im just gonna leave it
    see how long before its useless
  14. SQLGuy
    Interesting. I'm curious to hear how it's going to sound with those very different runner lengths.
  15. hardtailed81/85xj700
    missouri
  16. hardtailed81/85xj700
    missouri
    Seat I made last week
    stainless steel ..lambskin
  17. hardtailed81/85xj700
    missouri
    Ill let yah know how it goes
  18. cutlass79500
    lawrenceville georgia
    Those runners are so long throttle response will be in minutes . Usually they use accelerator pumps to compensate for loss of vac don't think it will work up hill gonna puddle. Hopefully it will work for you but do not be surprised if it does not. Watch 1 2 and 3 make sure if it does run you don't hole a piston. i do not believe there will be any gas getting to them. I saw someone try this with a small holley 4bbl told him it was not gonna work when it did not he went to 2 of them 1 on each side. Best of luck
  19. hardtailed81/85xj700
    missouri
    What do you think if I had a choke setup for the individual ports?
    You think it would help
  20. k-moe
    I think that you'd be much better off with a double-Y arrangement that places the carb between #2 and #3.
  21. SQLGuy
    I agree.
  22. hardtailed81/85xj700
    missouri
    Well i got it all hooked up
    it started quite easily and actually idled quite nicely around 1800-2000 rpm
    Im drawing vacuum from #4
    And so far it is looking ok with the plugs
    granted ive only let it idle for ten minutes three times
    oddly enough the throttle response seems somewhat normal
    Im keeping my eye on everything
  23. SQLGuy
    What I would be most concerned with is how the different runner lengths are going to interact at different speeds.... like if resonances and standing waves lead to starvation of one cylinder at certain engine speeds. When you see manifolds like yours in production designs, the shared tube or box is much larger than the runners.
    Cool to hear it's running, though. Allows you to eliminate a number of concerns from your tuning process.
  24. hardtailed81/85xj700
    missouri
  25. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Imo 1 and 2 will definitely starve and run too lean. 4 will always run too rich. The set up doesn't allow for slowing the fuel to 4 enough to not starve 1 and 2. I could be wrong.
    +1.
    Gary H.
  26. Dave in Ireland
    Ireland
    If you made a box plenum chamber with stubby outlets matching into the head inlets, and sat the carb directly on top - would there be enough headroom for the carb, including some form of intake filtration? A low-profile carb is probably available from something, and if necessary, a low-profile flat-section bend from the top of the carb to an air filter.
    With your current arrangement, I can see you might have horrible fuel drop-out issues when it gets a bit colder.
  27. hardtailed81/85xj700
    missouri
    Ok fellas did a redesign
    built 2 individual equal length steel box plenums fed directly from the bottom center and am still using the 1965 pict 28 vw carb
    Testing is going well ..plugs look great.....no cutting out.....dunno may be onto something here
  28. hardtailed81/85xj700
    missouri
  29. hardtailed81/85xj700
    missouri
    Carb isnt on in these pics
  30. Dave in Ireland
    Ireland
    Have you seen mine? - it really is simple. Only reason I didn't try a one-piece cross-ways plenum was the lack of height ot the top rails. You have a ton of room there.
  31. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Seems like a lot of manifold run. Does it hesitate when you crack the throttle?
    hardtailed81/85xj700 likes this.
  32. hardtailed81/85xj700
    missouri
    Where can I find that pic
    I looked ? Can you load one up on here id like to see it..thanks dave
  33. hardtailed81/85xj700
    missouri
    The throttle response is
  34. hogfiddles
    Is what?
  35. hardtailed81/85xj700
    missouri
    Throttle response is nice
    Surprisingly
  36. MN-Maxims
    Saint Paul, MN
    Amazing! Just seems like a lot of run and curves the fuel and air to navigate for positive throttle response.
    Seems like an interesting mod though. SQLGuy did his fuel injection a while ago and that was impressive
  37. quebecois59
    I'd be curious to see how wide it is with the air filter , from a sitting rider's point of view.
  38. SQLGuy
    I would think that a manifold like mine would work pretty well with a good sized MC carb (44mm or so) in the place of the throttle body I have in my setup.
  39. MN-Maxims
    Saint Paul, MN
    I would like to see that!
    quebecois59 likes this.
  40. quebecois59
    Were the adjustments minimal once you found the right manifold/throttle body setup?
  41. SQLGuy
    Well, there was a lot of learning involved before I got to that point. Part of that was because I had one of the first batch of 10 Microsquirts made. There were problems with the VR conditioning that they didn't solve 'til long after I had replaced the whole circuit. Initially they didn't believe those problems existed. Then they had a cure that made no sense. They finally did fix it in a later revision, though. Idle control was also a challenge, as was warm-up (most of the Megasquirt warm-up curves are idealized for water cooled engines).
    This is my second manifold design and third fuel rail design. I did work out a lot of the tuning on the first manifold, and things were smoother with the new design - as well as easier to install and more elegant. I haven't done any dyno work with the newer manifold, though, so I can't say how much of a difference it made in power; it does certainly feel like it runs better.
    It's hard to say how difficult or easy it would be if I were starting with the solution I have now and just needed to tune it. And there's still the question of how much better (if any) an ITB solution might be...
  42. SQLGuy
    Here's a less pretty picture of what the manifold looked like during construction. Gives a better idea of how the pipe pieces fit together. These are regular copper pipe fittings, mostly 45 degree pieces, since a pair of those can make a wide variety of curves. The intake port flanges are cut from brass sheet, and the throttle body flange is cut from a thicker copper sheet. Copper and brass allow for fairly forgiving assembly and tweaking with silver content solder and a propane torch. NewManifold2.jpg
  43. MN-Maxims
    Saint Paul, MN
    That manifold is so cool looking!
  44. quebecois59
    A piece of art !
  45. SQLGuy
    A piece of hack, more like. :) But it works, and it looks much better with paint on it!
  46. MattiThundrrr
    Nope, the copper looks cool! That could be the start of a decent theme ... instead of chrome, copper!
    SQLGuy likes this.
  47. Dave in Ireland
    Ireland
  48. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Steampunk!!!!
    SQLGuy likes this.
  49. MN-Maxims
    Saint Paul, MN
    Looks pretty good for a piece of hack if you ask me. I couldn't have done that in my wildest dreams. That's what makes this site so great is all the great ideas and people with real talent helping everyone. You are a very talented individual sir! Thanks for your insight and help with things like this.
