SAFETY ALERT Drum rear brake bike owners please take a look
Discussion in 'XJ Technical Chat' started by bigfitz52, Mar 6, 2009.
  1. XJ550H
    to help with the misunderstanding never repair brake shoes my dark sense of humor in another post was not well recieved
    quoting matti thundrr
    "In my opinion, there are two ways to deal with delamination: replace them, or die. (Slight exaggeration)"
    not an exaggeration you will die. Many years ago my brakes delaminated locked up the rear wheel solid. lucky i was not in traffic slid about 70 feet to a hard stop
  2. bunglejyme
    bunglejyme Member
    New Jersey
    Holy Crow! That's a recipe for disaster.
    XJ550H likes this.
  3. XJ550H
    thats why its pinned to the top of the tech forum must read for everyone and must do.
    its more important to be able to stop than go
  4. maddmick
    maddmick New Member
    brunswick wa australia
    Well as soon as i figure out how to remove a shaft driven back wheel. I will be lookin at replacing mine for sure
  5. chacal
    YYCMaxim and XJ550H like this.
  6. Mike Flores
    Mike Flores Member
    Auburn, WA
    That's exactly what I found on my 83 mid max when I put it on the road last year. When this happens the rear brakes will lock up unexpectedly! Very scary!!!
  7. XJ550H
    do we ever expect the rear brakes to lock up?:confused::eek: I had this happen many years ago just came out of a hard corner into the stright away......
  8. hogfiddles
    Yeah.... When you intentionally stomp on the pedal hard enough to lock the rear up. Just like we did when we were kids on our bicycles
  9. wkxj
    wkxj Member
    nm
    Yea I just got a basket case xj 550 that has been left outside for years and sure enough the rear brake pads are completely delaminated
    I thought I was the only one
  10. XJ550H
    sounds like how mine lookin my smart a@@ photo on page 8 of this post with the jb weld tubes.
    MAKE no attempts to fix brake shoes
  11. Mike Flores
    Mike Flores Member
    Auburn, WA
  12. Mike Flores
    Mike Flores Member
    Auburn, WA
  13. Turbo20
    Turbo20 Member
    Oshawa
    damn those are beat good thing you got to them before something happened, ill be checking mine tonight when i get home
  14. FrostyDog
    FrostyDog Member
    Canada
    Fitz you are awesome. I checked my brakes last weekend when I took my rear tire off to check out the bearings and before I put on my chain. If it weren't for your post I think I would've just done the bearings and called it good. Luckily mine were fine.
  15. XJ550H
    make it a regular thing to check, if you do not know how old they are you never know when they may start to fall apart.
  16. FrostyDog
    FrostyDog Member
    Canada
    Definitely. Once I get it going and roadworthy then that and tires are both getting done. They aren't that difficult or expensive so why not right?
    XJ550H likes this.
  17. GeekBikerGirl
    GeekBikerGirl Member
    Northampton, MA
    Did mine last summer. My fiance insisted on it.
    tcoop likes this.
  18. yellow_yellow
    yellow_yellow Member
    Ann Arbor, MI
    Just did mine. Better safe than sorry. Pretty easy process.
  19. greg_in_london
    greg_in_london Member
    London
    I feel like I'm getting old as I remember walking into auto shops and seeing brake linings hanging up, waiting to be glued on. I never fancied it though and fixing something that has come apart is a lot less reliable than fixing new materials together.
  20. XJ550H
    we are getting old I remember being able to buy kits to reline brakes
