Two piece handlebars triple tree. need help
Discussion in 'XJ Modifications' started by XJE, Nov 2, 2015.
  1. XJE
    XJE New Member
    Ontario
    Hello, I need some help from the experts of this site
    I have an 84 xj750rl with the two piece handle bars. the mount is cast to the tiple tree not bolted.
    I need to know which upper tree I need to convert it to pinch style bars. otherwise, what else do I need?
    Thank you for your input
    XJE
    you could use somthing like this with cup inverted onto serrated post bolt up to risers you want then single piece bars
  3. XJ550H
    or have a machine shop remove serrated portion.
    you could also have a machine shop cut the serrated portion off of the bottom of the handle bars and use it as a spacer
  4. hogfiddles
  5. Sebastian Uhde
    Sebastian Uhde Member
    Good Ol' South
  6. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    there's a solution in the (89 handlebar thread) on modifications forum
