best battery / solenoid salvage
Discussion in 'XJ Technical Chat' started by jtalafous, Nov 9, 2015.
  1. jtalafous
    jtalafous Member
    Austin, TX
    Two questions for those that have 1981-3 XJ550 or similar...
    1. In your experience, what is the exact brand of the best cold start battery I can buy? Anecdotal data welcome
    2. Is it possible to rebuild a starter solenoid or should I get a new one?
    XJ4ever!
    Joe
    solenoids are cheep just buy one do not think they are rebuildable.
    I got a lead acid battery 55$ at the local auto parts store work for me most important is to keep a full charge on the battery. trickle charger is good to have untill you can ride the bike regulary
    starts easily at 40 degrees
    i will post the brand in morning
  3. jtalafous
    jtalafous Member
    Austin, TX
    Thanks!
  4. XJ550H
    iit is an EXCIDE brand says to charge with 500m amp charger or a 2 amp charger with the auto charge feature.
    most parts stores will charge it for you.
    mine was a kit where you add the acid your self, good instructions sheet.
  5. joejr2
    Santa Fe,NM
    I saw a lot of motorcycle batteries for sale really cheap on ebay,but without acid. Where would one get battery acid ?
  6. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I use Remy.
    They fill that battery with acid when you purchase it.
  7. XJ550H
    auto parts store sell acid. it would be best to buy the battery localy. parts stores will fill and charge battery for you
  8. joejr2
    Santa Fe,NM
    Yeah, you're correct I was at autozone today and the counter guy said they sell acid by the pint. Unfortunately here in Santa Fe all
    the auto parts stores make you put in your own acid and the bike shops charge about double for batteries ready to go.
  9. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Try batterystuff.com. It comes in a couple of days, all charged and ready to install, and very reasonable.
  10. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I buy mine at local Campbells Supply farm and home store. Dont remember brand. I have to add acid and charge. So far current one lasted 3 seasons. Rapid starts in all attempts. Have started down to 40 degrees farenheit.
