1981 XJ 550 Seca -- Engine Rebuild
Discussion in 'XJ Technical Chat' started by robvoisea, Nov 21, 2015.
  1. robvoisea
    robvoisea Member
    seattle
    It happened, a couple of months ago, I am coming home from work and I noticed that beyond 60 mph, acceleration was pretty sluggish and at there was a constant metallic sound. With the help of some forum members determined that one of the connecting rod bearings was spun out.
    My question: does someone have some guidance, experience and suggestion in doing the engine rebuild? What things do I need to replace, is it almost cheaper to buy a different engine.
    I have never done anything like that and I am quite nervous with this project.
    Your help is seriously appreciated.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    My vote would be to find a different engine. The parts are not cheap and if you go through all the tear down and not replace chain guides and starter clutch parts because of the expense it's all for nothing unless you plan on keeping forever then go for it. I seem to see many bikes parted out and engines are plentiful.
  3. robvoisea
    robvoisea Member
    seattle
    Thank you.
    I will do both because this is my first bike and I have some sentimental value attached to that.
  4. robvoisea
    robvoisea Member
    seattle
    Can I put a newer engine in the frame, like a Seca II engine?
  5. k-moe
    It should bolt up. Same cases IIRC, but there may be some fitment differences.
  6. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Replace the engine, ebay is full of them from bike junkyards. Keep the old one and rebuild it as a project if you like, but be prepared to put at least $5-800 in parts not including labor.
    rocs82650 likes this.
  7. a100man
    a100man Well-Known Member
    Bedford, UK
    No Seca II (Diversion in Europe) won't fit. Entirely different top end with 'downdraught carbs' and inclined cylinders. Radian/FJ600/FZ600 will fit but if you intend to use teh bigger carbs of these engines then be prepared for some 'fun' with the rubber parts..
  8. k-moe
    IIRC the Seca 2 engines were tilted due to the frame design, but had the same cylinder base angle.
    XJ550
    Seca 2
    The intake runners are different to fit the downdraft carbs, but they should have the same bolt spacing ant port size as the 550 intakes.
    EDIT. Looking closer the Seca 2 does have a slightly wider cylinder base angle. :(
  9. a100man
    Bedford, UK
    If nothing else I think carbs will be the problem. Fit seca 2 carbs and it won't fit in the frame. Fit XJ550 head/carbs (if indeed possible) and the incline will screw-up the levels etc.. IMHO that is ;)
  10. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1.
    Also +1.
    Way too much trouble for the end result. I'd fit another 550 mill and be done with it. Varoom, varoom!
    Gary H.
  11. k-moe
    Actually....all this talk is making me want a Seca 2 again. It's been 20 years since I've even considered one.
  12. robvoisea
    robvoisea Member
    seattle
    Thank you very much guys.
    Sounds like I need to get a 'new' engine.
  13. MN-Maxims
    Saint Paul, MN
    There are always those garage queens with low miles that got stuffed away because it was too much money to get the carbs cleaned and the valves set by the dealer.
  14. darren ditmar
    darren ditmar Member
    eugene oregon
    if yoouo feel so inclined you could fit an yx600 engine in it if you cant find a 550 for some reason
