1981 xj650 engine?
Discussion in 'XJ Technical Chat' started by Chopper63d, Dec 18, 2015.
  1. Chopper63d
    Chopper63d New Member
    Santa fe springs
    Greeting's,
    I'm new to motorcycles, but I am mechanically incline. I'm an aircraft mechanic and done my share work on cars. I bought a 1981 yahama xj650 for 200$. The motor is blown so I decided to pick up a project and buy it. So I have the engine out and I'm looking for a new engine. I've noticed online for sale that there an engine xj650 seca turbo with black covers and then there the one I have that is a regular xj650 engine with grey covers. My question is how different are the engines? What engines am I able to use on my bike?
    Thank you
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Can you define 'blown' ? If its only top end (head pistons etc) it might be easier to refresh these. Like as not with any replacement engine you will have to partially strip to check valve clearances, de-coke etc..
  3. Chopper63d
    Santa fe springs
    I apologize I should of been more specific. There is a hole on the bottom end coming from cylinder #2.
  4. XJ550H
  5. SQLGuy
    SQLGuy Well-Known Member
    Usually, factory turbos have lower compression and different cam profiles. They often also add squirters (oil jets that hit the bottoms of the pistons) to cool the pistons.
    In the case of the XJ650s , NA is 9.2:1, and turbo is 8.2:1 for compression.
    Using a turbo engine without the turbo will definitely result in disappointing performance compared to a stock NA engine.
  6. Polock
    pretty sure a 750 goes in there with very minor mods
  7. a100man
    Bedford, UK
    Got a picture ?
  8. k-moe
    A 750 Maxim engine is a direct swap.
    Is the damage in the cylinder or in the engine case?
  9. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    What would you pay for engine with 6200 miles on it?
  10. Chopper63d
    Santa fe springs
    Attach are some picture of the engine.
    I have been looking online and I just wanted to get the best deal and the correct engine. Good to know that the 750 maxim engine is a direct swap.
    To be completely honest with you I dont really know how much they go for. I have been seeing that the engines are running from 150-350 without shipping. Do you have one? If so and if its a good deal I would be interested
  11. k-moe
    Nice hole. Slap on some JB weld and run it ;)
    I would do a teardown first. You'll want to inspect the internals anyway to see what can be sold to recoup some of the costs. If the spiny-round bits are in good order you might be able to find a good set of cases to swap (you'll want to confirm the bearing sizes in the replacement case if you go that route. New bearings can be spendy and diffficult to find).
    If you're really, really lucky that hole might have been caused by something other than a con rod letting loose.
  12. Polock
    does the exhaust attach the same with the collector vs the crossover pipe? i need to spend more time under my bike :)
  13. k-moe
    The 750 uses a collecter instead of the crossover that the 650 has.
  14. Chopper63d
    Santa fe springs
    The 650/750 "yics" system, is that only in the carburetors? My bike doesn't have the yics system and wondering if I can use a 650/750 yics engine on my bike. From looking on eBay there's only one engine for sale just like mine.
  15. k-moe
    The YICS system is part of the cylinders and head. You can swap in a YICS engine wihout needing to do anything special. The jetting on the YICS engines was slightly leaner, but you can run your carbs as-is.
  16. hogfiddles
  17. memphis
    memphis Member
    Cheltenham/UK
    Xj900 pre-diversion is a straight swop. Don't get turbo. Too much hassle with pressurised carbs and leaking turbo.
  18. Chopper63d
    Santa fe springs
    I got a hold of a xj650 engine. Thank you everyone for the help.
  19. MN-Maxims
    Saint Paul, MN
    Ok
    If anyone is looking for a low mile great runner engine PM Me
  20. hogfiddles
    Uh.... NOT.
  21. k-moe
    Oh it'll fit Dave. You just need a grinder and a welder, and the requsite skills to use them. ;)
  22. hogfiddles
    I know that.
    No, its NOT
    And here's why not...... Lol
    Not to mention the rest of the things that need to be accommodated
  23. memphis
    memphis Member
    Cheltenham/UK
    Uh. Yes. That's what I have on my xj now
  24. k-moe
    In a Maxim 650 frame? Pics please.
  25. hogfiddles
    Physically, the engine fits in the space, albeit a tight fit, but there are things that need to be done..... It's not just plug-n-play
  26. Chrisbillybob
    Chrisbillybob New Member
    Pearl ms
    I have a 1981 xj650 that has a rattle in the gears which would be cheeper replaceing the motor or the gears?
  27. k-moe
    Diagnosing the problem first will be cheaper than diving in and assuming that something needs to be replaced. Start a thread and describe the problem as thoroughly as you can.
  28. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Any motor will fit with some creativity
  29. hogfiddles
    From Len:
    * when putting an XJ900 engine into a XJ650 Maxim, Midnight Maxim, or RJ Seca frame, please observe the following changes:
    - although there are anecdotal stories of this swap being accomplished, we've never seen or verified the completion of such a project. There may be some engineering challenges involved due to the greater height of the XJ900 engines, as well as other issues.
    Besides that, the same guidelines as generally outlined in the XJ700 engine swap should be observed.
  30. hogfiddles
    For all the swap info, go to the information overload hour, scroll down to the section on Engine Swaps
  31. k-moe
    Go for it.
