My rebuild post
Discussion in 'XJ Technical Chat' started by Newb21, Dec 11, 2013.
  1. hogfiddles
    Ever notice you rarely see an engine for sale that is described as "seized up tight sometime long before the last time I tried to ride it"?
    Glad you got a refund...
  2. Newb21
    Newb21 Member
    Cardiff, South Wales
    Yeah I guess so, it came from a breakers who said it was turning over when they stripped the bike but had to drain fluids to store, which was 3 months before I bought it. I can't get the head off at the moment because of the way the cam shafts are positioned I can't get to the bolts to release the sprockets. I've tried removing the tensioner and slipping the chain, but can't rotate the cams or get the chain off.Unless there's another way I'm missing?
  3. hogfiddles
    Separate the chain..... Get a chain breaking tool, or, if you don't care about the chain then just cut it.
  4. Newb21
    Newb21 Member
    Thought about that. It'll mean an engine rebuild right?
  5. Newb21
    Newb21 Member
    To put a new chain in meant...
  6. hogfiddles
    If you cut the chain, yes. If you use a chain breaker, no. The breaking tool pushes the rivet out. Tie a string to the chain. Pull the chain through, the string will be used to pull a new chain through.... Or him the new chain to the old chain. The tool also installs the new rivet.
    BUT, if you have a chain with high miles or unknown miles, why not just put a new one in anyway?
    Last question.... If you're talking about the new engine you got- you're gonna do a rebuild of a seized engine anyway, right? Put a new chain in.
  7. Newb21
    Newb21 Member
    Yeah the new engine. The seizure is in in the barrels I was hoping not to have to replace to much, I'm expecting to have to change the barrels. I've got a chain breaker/riveter so will look into replacing the chain as well.
  8. k-moe
    If you can get Acetone there, use it and an equal amount of Automatic Transmission Fluid. That is the best penetrating oil ever devised.
    Heat can be your friend here too. Heat the barrels with a torch, allow the engine to cool, and repeat the process several times to help break the rust up.
  9. Newb21
    Newb21 Member
    Yeah. I can get Acetone I'm pretty sure the Mrs uses it to remove false nails lol. I'll look into the Moe. Cheers Buddy!
  10. hogfiddles
    Don't use the scented kind
  11. Newb21
    Newb21 Member
  12. hogfiddles
    That'll be fine
    Newb21 likes this.
  13. k-moe
    Don't you like your motorcycle to smell pretty?
  14. Newb21
    Newb21 Member
    The smell if burning fuel is enough for me. Petty mine isn't burning any at the moment!
  15. willyworm
    willyworm New Member
    Rhode Island/California
    any news on the tear down? Im about to start an engine rebuildish myself and am trying to find info
