New to group and need help... 82 xj750 Maxim with pods issue starting
Discussion in 'XJ Technical Chat' started by BlackBettyXJ750, Nov 9, 2015.
  1. BlackBettyXJ750
    BlackBettyXJ750 New Member
    Georgia
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
  3. jpacman
    jpacman Member
    East Central Vermont
    Yep. All the rules of carb tuning will apply including adjusting for pod air filters. Make sure your enrichment ports are all clear, the floats are set properly, the jets are clean, etc. There are basics of fuel flow pertaining to the fuel petcock but even then the carbs must be tuned properly.
  4. Core
    Core Active Member
    Switzerland
    Hey that is a bad looking ride mate. (bad as in good)
    Any pics with the seat on?
  5. Ribo
    Ribo Prefectionist
    I see the front end has been lowered by pushing the forks up the tree. You might still have an issue in the corners without having a front fender or fork-brace.
  6. XJ550H
    what are your starting issues can not tell from the pictures. need discription of problem.
    did you clean the carbs?
    there is an enrichment circuit (choke) and the pilot jets which deal with starting the bike.
    the pods will not keep you from starting the bike just fine tuning.
    side note is your battery fully charged this will prevent starting
    we have another member who calls his bike Black Betty
    that front brake line looks real bad and needs to be replaced real soon
  7. rocs82650
    Middle Tennessee
    +1.
    Gary H.
